standalone verion
aimhigh
standalone verion
Post by aimhigh » Mon Jun 05, 2023 9:34 am
Hi folks,
is it possibe to compile a standalone version of qcad, so I can run it from my pen drive?
Re: standalone verion
Post by andrew » Mon Jun 05, 2023 9:41 am
There is a tutorial for this at:
https://www.qcad.org/en/qcad-portable
aimhigh
Post by aimhigh » Mon Jun 05, 2023 10:00 am
So qcad does not need any libraries of the OS at all?
Post by andrew » Tue Jun 06, 2023 8:36 am
QCAD does need various system libraries (like any other software). These libraries need to be present on the system where QCAD is run. However, these are all standard libraries which are typically present on every installation of that system.
