QCAD overlaps bottom of screen, cannot move it
BobKnobloch
Post by BobKnobloch » Thu Jul 31, 2025 11:09 am
Hi, I have installed qcadcam (qcadcam-3.32.3-trial-linux-qt5.14-x86_64) on Opensuse 15.6 - KDE Plasma5.
The qcad window exceeds the lower boundary of the screen (1920 x 1080 pixels) so that it is not possible to get to the bottom of the window to drag it up. The top bar does not allow dragging and un-maximising the qcad window leaves the bottom of the window still not accessible.
That is the width can be changed but not the height.
Any ideas?
Bob
Re: QCAD overlaps bottom of screen, cannot move it
Post by andrew » Thu Jul 31, 2025 4:54 pm
Please close some or all of the widgets at the right (layer list, block list, etc.). After this, you should be able to resize the application window or switch to full screen (Window > Full Screen).
