Vector through Windows Printer Interface
Posted: Tue Dec 23, 2025 4:51 pm
Hi !
I am evaluating QCAD and I am impressed with the user interface.
However, it seems that every print is rendered in pixels, never vectors.
I am using an Epilog Zing Laser that has a printer management interface which can sort out vectors from scanning/rastering.
So I can engrave letters into Rowmark material and then cut it out in a second pass.
I was using the little known program Tenado CAD. This one can utilize both, vector and raster with normal printers.
Wen I print as PDF for instance all the lines can also be vectors in the PDF.
My question is now: Can QCAD do the same thing using the WIndows Printer Interface?
QCAD 3.32.4.0 (3.32.4) on Windows 11 24H2
