SVG2DWG preserving layers
bens
Post by bens » Tue Aug 02, 2016 8:42 pm
Hi...another question if I may
when SVG2DWG'ng...is it possible to preserve the layers? I ask this because If I were to DWG2SVG and then SVG2DWG the resulting DWG only has one layer
cheers!
Ben
Re: SVG2DWG preserving layers
Post by andrew » Wed Aug 03, 2016 8:56 am
No. SVG does not support any concept that could be interpreted as layers, although some SVG applications like Inkscape emulate layers in their own way.
bens
Post by bens » Sat Aug 06, 2016 7:36 pm
ok, that makes sense.
Cheers for getting back to me
Ben
