how to overlap two drawing?
eamontsai
Post by eamontsai » Fri Nov 18, 2016 3:12 am
I want to overlap the two drawing,
I copy right drawing to paste left drawing but the center point can't be aligned.
How can i do ? Please help, thanks~!!
Re: how to overlap two drawing?
Post by Husky » Fri Nov 18, 2016 5:33 am
Husky wrote:Hello eamontsai - welcome to the forum!
eamontsai wrote:I want to overlap the two drawing,
below is picture link.
My Website scanner told me that this link leads to an infected site - please post the picture to your post - thank you!
How to Attach a File to a Post: http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3760
eamontsai
Post by eamontsai » Fri Nov 18, 2016 7:16 am
Hi Husky:
I attached the picture and I think I have may found a solution for this problem.
solve:
1.found right drawing's center point.
2.select right drawing.
3.choose "Modify"-->"Move"
4. cursor move the center point and click the point, and you can move the drawing to any where
5.move to the left drawing's center point
6.overlap two drawing.
Post by Husky » Fri Nov 18, 2016 7:43 am
Looks good! :D
Maybe you like also to check out the Snap tool "Middle manual". This tool will snap to the middle of two given points. :wink:
