upgrade to pro
jose
upgrade to pro
Post by jose » Mon Jul 16, 2018 3:33 pm
Mac
using free quad
when uploading pro version do I need to delete free version?
Re: upgrade to pro
Post by andrew » Mon Jul 16, 2018 3:39 pm
Previously Installed Trial Version
If you have previously installed a trial version, you may want to uninstall that first as this is no longer needed.
- Under Windows, you can simply install the full version over the trial version using the downloaded MSI installer.
- Under macOS, drag "QCAD.app" in Applications to the Trash to remove the trial version. The full version is called "QCAD-Pro.app"
- Under Linux, trial and full versions are installed into separate directories. Simply delete the directory of the trial version in the opt folder of your home directory.
jose
Re: upgrade to pro
Post by jose » Mon Jul 16, 2018 10:59 pm
Guess you never sleep?
In ACAD I could work in viewport and would change in model space.
I assume with Qcad I cannot do this after playing around some?
Re: upgrade to pro
Post by andrew » Mon Jul 16, 2018 11:09 pm
I'm not quite sure I understand your question..
You would usually change the model space and viewports are updated to reflect the changes.
See also:
https://qcad.org/en/tutorial-working-wi ... -viewports
Re: upgrade to pro
Post by Husky » Mon Jul 16, 2018 11:52 pm
Correct - that isn't possible in the current QCAD Pro version. Anyway in my opinion that isn't the idea behind a "Viewport. Just my two cents ... :wink:
But - if you use the standard Print Preview (launched from the Model Space) you are able to modify the drawing in the Print Preview which will modify the "Model Space" too.
jose
Re: upgrade to pro
Post by jose » Tue Jul 17, 2018 10:38 am
ThankS
In QCAD it nice that you can move viewports around in paperspace and not have to rearrange modelspace!
