Hardware configuration
massaut
Post by massaut » Thu Dec 13, 2018 2:49 pm
Hello guys, I have a question.. What is the minimum configuration to use the qcad professional in a computer with windows ?
thanks
Re: Hardware configuration
Post by andrew » Thu Dec 13, 2018 3:03 pm
You can find the recommended minimum requirements at:
https://qcad.org/en/faq
