QCAD for an architect
ggsalas
Post by ggsalas » Mon Jan 26, 2009 7:59 pm
Hello, I am considering purchasing Qcad, but not if it meets my needs.
I wish I could download Architectural drawings made Qcad. This way I can know how it is used.
I can not find the tools that are:
- Accumulated dim: to draw a drawing of rethinking of concrete, for example.
(http://www.ribbonsoft.com/rsforum/viewt ... =1936#1936)
- Layout of a plane with drawings at different scales: in municipal plans, construction details, for example.
(http://www.ribbonsoft.com/rsforum/viewt ... highlight=)
Finally, I had trouble opening documents by DWG "EveryDWG" (with Wine): Create hundreds of blocks (for each dim) and runs very slow to open or not open.
I do not need 100% compatibility with AutoCAD, but if I need to open and edit drawings.
Thank you. I wish I could help improve Qcad is very important for me to use a free (not like beer) cad on GNU/Linux. I think that QCad is the best option.
Post by andrew » Tue Jan 27, 2009 10:45 am
Thanks for your valuable feedback.
