Does QCAD Prof run offline?
reichj
Post by reichj » Fri Nov 01, 2019 4:04 pm
I would like to verify that the licensing mechanism does not require connection to the internet or is tethered to a licensing server.
Can QCAD and the license file be installed and executed on a PC with no internet connection?
thank you.
Re: Does QCAD Prof run offline?
Post by andrew » Fri Nov 01, 2019 4:51 pm
QCAD does not require an Internet connection for anything except for checking if there's a new version which is entirely optional.
