Getting a new copy
G4DCP
Getting a new copy
Post by G4DCP » Thu Apr 23, 2020 8:25 pm
Andrew
I have use QCAD/QCAM in the past and purchased a licence in 2016.
The order was 114107.
Do you have any current update plan? Can I order an update and if so how.
Many thanks
Peter D Hull
G4DCP
Re: Getting a new copy
Post by andrew » Fri Apr 24, 2020 9:02 am
I just sent you an e-mail with information about updates and and update discount code.
G4DCP
Post by G4DCP » Wed Apr 29, 2020 6:44 pm
Thanks,
I saw the private message unfortunately the link gives 404 not found.
Peter
Post by andrew » Wed Apr 29, 2020 11:15 pm
I had sent you a message via e-mail. Please check also your spam folder.
The private message you are referring to was sent in 2017 and was referring to a temporary download link that is indeed no longer valid.
I've also sent the same update information as private message to you again in case you cannot track down the e-mail.
