Hi All,
I am new and I am considering on purchasing the software but I need to see if you all can help me with this.
I used to use Autocad to draw this and I am wondering if someone can help me if this software is able to do the same and how?
Thank you.
Help
Help
- 2 Reunion Grove NW.pdf
- (37.37 KiB) Downloaded 552 times
Re: Help
Yes, this is the type of drawing you can do with QCAD. Dimensions will look slightly different in QCAD though.
The "how" question cannot be answered in short. You'll have to use the various tools the QCAD offers to draw the various elements of your drawing. I'd start with the rectangles (for example using Draw > Rectangle with Size). Then use use the offset tool for the inner rectangles, hatch the area and in the end add the dimensions and the border.
Feel free to post back if you have any more specific questions.
- petevick
Re: Help
yes it can, it will do it much the same way as Autocad. I have an Autocad background, and It took me about a week, on and off, to pick up the basics and use Qcad in a meaningful way, If you can use Autcad, you can use Qcad.
Pete Vickerstaff
Re: Help
Yep - second that. QCAD has all the tools to easily accomplish a drawing like that one. In short: Piece of cake with QCAD!
Re: Help
I use this to do schematic drawing of the layout of houses. So I often start with the width (side to side of the rear fo the house). I need to be able to enter a 28'6" line horizontally.I always do multiple lines with various dimensions and mostly at right angles and some at 45 degrees.
- 234 Williamstown Green NW.pdf
- (43.66 KiB) Downloaded 529 times
Re: Help
Still a piece of cake for QCAD.
To test it by yourself I recommend to download the free trial version of QCAD Pro below:
https://www.qcad.org/en/qcad-downloads-trial
Re: Help
Please ask for direct help on this forum.
Attach your trials and explain your problem.
For the free trial that would be in the QCAD Community Edition section or simply use the Chat section.
I am sure someone will jump in ...
Don't mind asking silly questions, such don't exist, there are only silly answers.
Getting used to a new application can have a steep learning curve.
Once past that, QCAD is fun ...
