Get ATTRIB entities
Use this forum to ask questions about how to do things in dxflib.
h0rus
Get ATTRIB entities
Post by h0rus » Mon Jul 13, 2015 3:33 pm
Hi guys!
I'm still new to dxf manipulation, and i am currently trying to get attributes from blocks (i'm talking about those: http://www.ellenfinkelstein.com/acadblo ... ttributes/).
I get that DL_CreationAdapter::endSequence() is called when an ATTRIB entity is done, but I still can't get to know when such an entity begins...
Any help would be grealty appreciated :)
Re: Get ATTRIB entities
Post by andrew » Mon Jul 13, 2015 4:00 pm
DL_CreationAdapter::addAttribute(...) is called to add attributes.
Notes:
- attributes are text entities like any other text entities with an additional property called 'tag'
- attributes exist on the same level as the block reference they belong to
- attributes are typically created from attribute definitions present inside block definitions
- attribute definitions are currently NOT supported by dxflib
h0rus
Post by h0rus » Mon Jul 13, 2015 4:16 pm
Thank you so much for the quick answer! :)
Weird, I didn't see any reference to DL_CreationAdapter::addAttribute() in the documentation...
Does that mean I simply cannot get block attributes with their tags? (this would be bad news for me ^^')
Post by andrew » Mon Jul 13, 2015 4:19 pm
You can get block attributes (they live independently of block attribute definitions).
You cannot get block attribute definitions, they are not currently supported.
Return to “dxflib 'How Do I' Questions”
