reading dxf
Use this forum to ask questions about how to do things in dxflib.
RobinCris
reading dxf
Post by RobinCris » Sun Aug 02, 2015 10:06 am
Hello.
I am building a small automation to read dxf files.
All the dxf files are made by me, so I decide their format.
I can choose to use blocks instead of polylines for example)
Every layer is a building floor.
In this example.
The hatch color is the area type.
1. Some of the lines in the area, need to be different (different materials). what can I do that I will be able to read it automatically (both different color or line type do not work with polyline).
2. I need to put something on the walls (lines) to represent windows. I need to connect it to a specific line with the height and width information. and read automaticly from the dxf file.
This is a 2D drawing not 3D.
Any ideas
Please advice
Re: reading dxf
Post by andrew » Tue Aug 18, 2015 10:31 am
RobinCris wrote:1. Some of the lines in the area, need to be different (different materials). what can I do that I will be able to read it automatically (both different color or line type do not work with polyline).
Both should work fine, also with polylines.
You could use blocks for this. It's also possible to attache additional information to entities (XData) which is then processed through addXData[String|Real|Int] in your DL_CreationInterface implementation.
Please elaborate if that's not what you meant.
Return to “dxflib 'How Do I' Questions”
