LWPOLYLINE not following spec strictly
If you are having problems with dxflib, post here. Please report bugs here.
dvlierop
Post by dvlierop » Mon Jun 19, 2017 8:22 pm
FreeCAD exports a R11 file with a polyline, having (x, y, z) coordinates. When I convert this file to a R15 using QCAD, then I get a lwpolyline, having also (x, y, z) coordinates. However, the z coordinate is not defined in the DXF specification for the lwpolyline, and might confuse other tools (such as in my case ezdxf).
I couldn't find out how to file a bug report in the tracker, so that's why I'm reporting here.
Nevertheless, thanks a lot otherwise for your great tools!
Diederik
Re: LWPOLYLINE not following spec strictly
Post by andrew » Tue Jun 20, 2017 7:56 am
dvlierop
Post by dvlierop » Wed Jun 21, 2017 9:14 pm
Thanks a lot Andrew!
Return to “dxflib Troubleshooting and Problems”
