Inside Hatches, more than meets the eye
Re: Inside Hatches, more than meets the eye
BTW @1000000 Is as far as the Hatchkit guys go.
Their example is metric @25000000.
All,
I think we might have hit a snag here. I can not call it a bug.
What I presume is that Qcad calculates all the offsetted paralles and shifts endlessly
and that AC at some point re-calculates a new origin and starts over from there.
>>EDIT: Redrawn, read further: John hitted the AC limit.
And that can be done with some proper math and with higher precision.
Its kinda the way I came, reversed engineering down to Tiles.
The next step back to tiled cartesians restricted the cartesians themselves to a grid.
What I did not liked because that could not be the goal of all the effort.
on top:
If you would re-origin every tile you get SuperHatch capabilities.
I don't mind. I am glad I found the limit.
I'll adapt the decimal digit heuristics to that.
It will limit good coherence up to 500000x500000 tiles away.
But gives us far better cartesian precision inside 1 tile. Far neater designs.
instead of 0.01x0.01 we can go up to 0.0001x0.0001 in imperial.
Metric users always get 25.4 times less, but it is the same percentage.
The difference for the users, none.
Simply send a notice to the Qcad crowd that it is good practice to keep the hatch origin near the hatch.
Hatches that span more then 1000000 tiles will eventually loose coherence.
Nobody is doing that!!!
It is better to chage the units long before that.
on top:
Hi CVH
So are we so to speak "flogging a dead horse" ?
We stick to basic patterns 0,45 & 90 degrees? for standard hatches
Maybe the curved patterns can be addressed with
a ..... here we go again...... DXFTILE?
Adding another 0 onto 1000000 and AutoCad begins to struggle too..
Unless maybe you can come up with a way to optimize the patterns
so they don't use so many decimal places without loosing quality...
I have no idea, I don't do this sort of coding and because of that I
didn't understand Andrews answer to you..
AC might use long doubles or rely on the 16th digit of 15,95.... Ha
Sorry, could not temper myself.
Correct form one point: 0,45,90,135... do not have decimals, so the don't loose any.
There are also x.99999999abc ones with little or no absolute fault.
Apart from the non-clones (0,45,90...) there are also 1-2-3-4-5...9 clones.
At least 10 times 10 times less sensitive.
And that is what you see far away. Some stay coherent, some not.
I'll keep them coherent up to a certain point.
Solved & Explained !!
A smaller absolute value repeated gets less faster in trouble with the 15-16 significant digits.
The sign does not matter apart that it has to be stored in the 80 characters limit.
e.g. 240.0684...° : 8.062214... or -(30.016650...)
e.g. 315.8069...° : 48.795487... or -( 1.414073...)
Tool adapts now.
C++ double is a 64 bit IEEE 754 double precision Floating Point Number.John Hyslop wrote: ↑Fri Jan 17, 2020 11:40 amI have no idea, I don't do this sort of coding and because of that I
(1 bit for the sign, 11 bits for the exponent, and 52* bits for the value).
*) All other values but "0" assume an invisible “1” in front.
52-53 bits binairy resolution.
The longest number that can be represented is:
2^53 = "9007199254740992" or about 15.95 digits (=log10(...))
The actual longest number that really fits is "0999999999999999"
= 15 significant digits
But in special 15.95 is meaning that taking 16 digits for true will flaw in 5% for the 16th digit.
Most results are from more then one calculation, with increasing uncertainty for the 16th digit.
Some C++ compilers take it the safe way. 15 significant digits.
Patterns will fail far away when the integer part needs more digits and the decimal part looses its accuracy.
I can not beat the used numerical system.John Hyslop wrote: ↑Fri Jan 17, 2020 11:40 amUnless maybe you can come up with a way to optimize the patterns
But they are as optimized as possible.
On top:
As you can see above it is angle related.
Recoding is not that hard:
In inch one can stretch this up to 100000 inch away.
In inch one can stretch this up to 180000 inch away.
Hi CVH
Thanks for the explanation I understood some of it
I think it might be a good idea to add a comment to users that hatch far away from the origin to edit the hatch properties to set the hatch origin back to X 0 Y 0
To reset the pattern...
I did put a note at the start of the "Free Hatch Patterns" topic saying that some patients will fail or become scattered...but put in your words..
We just have a limitation but there is the above workaround...not the best solution as I know you wanted to take this above and beyond with all your great ideas.
Anyway..I might post the hatches I removed and add notes...the only ones that render nicely far away from 0,0 are the basic ones 90 and 0 degrees and increments of these, anything with an angle even 45deg breaks apart
I still think what you've created so far is great it's just the limitations of Qcad....but as you say not many people would hatch that far away from origin...and we have above workaround..
In that we agree, I think it would be a standard notice or even a default behavior when 'hatching'.John Hyslop wrote: ↑Mon Jan 20, 2020 12:49 amI think it might be a good idea to add a comment to users that hatch far away from the origin to edit the hatch properties to set the hatch origin back to X 0 Y 0
Like I showed, recoding is done in a few minutes.
I did it aside while writing the post.
I started with < ar-conc.pat > but discovered that it is a strange fish.
This pattern is a collection of definitions based on mixed tile sizes so it looks more random.
so I took the Qcad gravel pattern like the Hatchkit example.
After generation, I discoverred the flaw at (0,0.78) ; Corrected it to 0.77 and redone it.
With that successfull, I processed the original QCAD-LOGO.
Fill in names, moving and rebooting took the longest.
After recoding the patterns are as less sensitive as possible on Qcad.
What I can't fix is the truncated 2 decimal digits of the examples what could be 4 digits in this case.
For that one has to restart from an existing or new master design.
With neater results possible.
Thanks, maybe even clearer with this:
With 15 significant digits one can represent:
abcdefghijklmno.000
abcdefghijklmno0000.000
abcdefghij.klmno
0.000abcdefghijklmno
But never: abcdefghijklmno.pqrst
Never a huge number and a high accuracy at the same time.
It was nececary to hit these limits.
There is a lot of scaling going on (times 1 for now).
Scaling required a stable decimal digit strategy.
Cheers,
Hi CVH
This may be of interest to you... Autocad has the same problems with hatches but have system settings to reset the origin..
https://knowledge.autodesk.com/support/ ... rigin.html
Let me know what you think..
John,
Sure, on the origin thing we have already launched the advice.
EDIT: 2posts up see
Apart from that I am still at the hatch generation step.
Tutorials for users or advice for Andrew is still way ahead.
Cheers,
That it would be nice that this would be automated at the moment of generation I think I did mention somewhere.
EDIT: 2posts up see
Cheers,
Hi CVH
Hatch Pattern drifting and shifting of entities seems to be a very common problem even with AutoCAD too,
they suggest also to reset the origin
https://autocadtips1.com/2017/07/24/fix ... h-pattern/
John,
ok,
we know that by now.
But what makes Gravel-01 so much more stable as Garvel.
That is the big question.
I have them side by side for comparison.
Altough it isn't straightforward because a lot of segments have a reversed orientation.
And even more:
Why does 0.0902033691118° works out for YukonRubble @ Tile (!635! ,1)
While it should be 0,0902294994465307...° at that addres.
Simply equal to the Inverse tangent of 1/635.
AR-CONC-01 that you have to explain in detail to me.
That originates from a multi layer hatch.
Cheers,
ok,
And even more:
Cheers,
Hi CVH
I've given users the wrong information... I said to set the origin to X0Y0 on objects far from drawing datum
I should of said set Hatch origin to object datum.... see screenshot example of GRAVEL Hatch Pattern.. also
included is dxf file in mm's..the 2 objects were drawn 1st then the hatch patterns applied..
- Hatch Origins - Gravel - mm.dxf
- (204.04 KiB) Downloaded 1321 times
- Hatch Origins - Gravel - mm.jpg (113.09 KiB) Viewed 20672 times
Corrected the quoted a bit.
Remark here the use off the nominator 'tiles' and not units.
It is all an angle thing related to the use of a grid like structure.
And meanwhile we also know it is a huge tradeoff between detailed and accurate OR lookalike and stable.
Even with a 0.01 drawing grid in a unit tile one can draw segments that don't hold for 10,000 tiles.
Second most important is how to use the 80 characters wisely.
We have to put things in there like:
Simply a line from (0.99,0.01) to (0.01,0.02)
0.01 grid: 179.415369479295,0.99,0.01,0.999947942424286,0.0102035504329009,0.980051,-97.0250509080129
my solution is:
179.41536948,.99,.01,.999947942424286,.0102035504329009,.98005,-97.0250509080129
Keeping most up to 15 significant digits.
But also:
0.001 grid: 134.912968503119,0.529,0.108,465.98390530091,0.000716056673849367,0.34215,-1396.19535397188
134.9129685,.529,.108,465.98390530091,.000716056673849367,.34215,-1396.19535397188
Is still 82 long and reducing to 80 will decrease acuracy.
