Script file encoding
Discussion forum for contributors and developers who are using the QCAD ECMAScript development platform or the C++ plugin interface or who are otherwise looking to contribute to QCAD (translations, documentation, etc).
Post by CVH » Sun Mar 22, 2020 11:33 pm
Interesting to know, also seen some related topics and other less related as the multi line command pasting.
viewtopic.php?f=89&t=7077#p27256
The problem in this topic was the umlaut sign is encoded different in ANSI.
Qcad reads the script as if it is encoded in UTF-8.
Could also be the reason that some of my coding fails at specific points.
Getting my own code back by a fresh install it seems no longer to be an issue....
Developing further the same issues popped up.
Next effort I will enforce NPP to use UTF-8 and see where that brings us.
Avoiding UTF-8 BOM because the BOM is again a windows thing.
CVH.
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Return to “QCAD Developers and Contributors”
