Qcad Theme Apps
petevick
Qcad Theme Apps
Post by petevick » Sat May 07, 2022 6:40 am
Qcad Theme Apps ~ latest versions
Qcad Theme Designer version 5.2.1 - https://www.qcad.org/rsforum/viewtopic. ... 116#p43116
Qcad Theme Lite version 2.6 - https://www.qcad.org/rsforum/viewtopic. ... 631#p42631
Qcad User Theme version 7.6 - https://www.qcad.org/rsforum/viewtopic. ... 760#p37760 (no longer supported or updated)
Pete Vickerstaff
Linux Mint 21.2 Cinnamon, Qcad Pro 3.29.6
petevick
Re: Qcad Theme Apps
Post by petevick » Tue May 10, 2022 2:37 pm
This is the home for all future versions of any Qcad Theme App, this includes Qcad User Theme, Qcad Theme Designer, Qcad Theme Lite and possibly Qcad Theme TabBar.
Any future version of a Qcad Theme App will come packaged as an installer / uninstaller.
For Windows the installer is a familiar looking app created using Inno Setup. The download will consist of a single .exe file.
See the screen shots below.
Win Install.png (86.09 KiB) Viewed 13607 times
For Linux the installer is Qcad Theme App Installer, a bespoke installer written by myself, it's very easy to use and has options that you don't get with the usual deb install package. The download will consist of a single zip file which contains one folder, the folder has within it two files, QcadThemeAppInstaller and a resource file. Unzip the folder to a writeable location, i.e. your desktop, and launch the QcadThemeAppInstaller file to launch the installer. Any pertinent details will appear in the upper information area, this area will change as the various options are checked and unchecked. Depending on how much information is being displayed, a vertical scroll bar will be displayed.
If you are installing to a 32 bit Linux system, and you have selected to create start menu launchers, you will probably need to log out and log in to display the Qcad Theme Apps start menu category.
Linux Install.png (143.93 KiB) Viewed 13607 times
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Tue May 10, 2022 2:41 pm
Qcad Theme Designer update, version 3.5
Version 3.5 is a significant update, it introduces some major additions and changes, and a few bug fixes, all as listed below.
ADDITIONS
  • The majority of the tool buttons have been deleted and moved to a new drop down menu system. The new menus are as follows...
    • File menu - Open, Save, SaveAs, Copy to Qcad and Quit.
    • Edit menu - Undo and Redo.
    • View menu - Load Default Stylesheet and Reload Configuration File.
    • Preferences menu - Backup and three new options, Browser Position Central, Magnetic Menu Shortcuts and Default Qcad Path.
    • Help menu - About, Stylesheet Basic Information and the new Show Menu Shortcuts.
  • To compliment the new drop down menu system, a Menu Shortcuts dialogue box has been added. This can remain visible whilst still using the main app. The position of this dialogue is saved to the configuration file. It is accessed via the menu item Help > Show menu shortcuts, or press F3 to show/close the dialogue. If you move the app this dialogue box will move with it, you can stop this behaviour by unchecking the Preferences > Magnetic Menu Shortcuts menu item.
  • An Autofill Hue slider has been added to complement the AutoFill Brightness slider. The Adjust Autofill colour sample is updated as the slider is adjusted. The Hue value, like the brightness value, is saved with the stylesheet. The Hue value is also displayed in the File Info dialogue.
  • Icons have been added to the AutoFill Brightness and Autofill Hue sliders. This is to differentiate between the two sliders.
  • You can now double click either the Hue or Brightness slider to reset it to the value saved in the current stylesheet. You can also double click either slider icon to set the slider value to zero.
  • The Backup state is now saved to the configuration file. This option is accessed from the menu item Preferences > Backup Stylesheet
  • The default Qcad folder can now be set via the menu item Preferences > Default Qcad Folder, or by pressing F6. The path to this folder is saved to the configuration file.
  • You can now use Ctrl+Enter to Select a stylesheet folder in the browser.
  • The position of the browser is now saved to the configuration file. This can be overridden by the menu item Preferences > Browser Position Central.
  • A Select menu item has been added to the browser popup menu.
  • Support for dark themes has been added for Linux and Windows.
CHANGES
  • All the tool buttons have been replaced by buttons that are more obvious when one has focus, or when the cursor hovers over a tool button, and they are easier to see when using the Tab key to move between the buttons, sliders etc.
  • The currently active tabs font colour is now dark red (Linux only).
  • The Check Icons colour drop down list has been replaced with a similar style to the new tool buttons.
  • The Adjust AutoFill Colour slider has been renamed to AutoFill Brightness.
  • The AutoFill Brightness slider has been replaced with a similar style to the new tool buttons. The upper limit has also been increased from +6 to +12.
  • There have been many general visual changes to the tabbed preview area. Specific changes have been made to make the following preview areas look more like the same areas in Qcad...
    • Combo List
    • Menu
    • Scroll bars
    • Tool Matrix
  • The tool buttons in the browser have been replaced with the same style as used in the main app. The icons have also been improved upon.
  • When the default stylesheet is loaded and you click Save, a message is now displayed from where you can click OK to use the SaveAs command.
  • The message that used to be displayed in SaveAs if changes had been made has been deleted.
FIXED BUGS
  • An error would occur if the stylesheet.qss file was missing from the do-not-delete folder.
  • Odd browser behaviour in Windows OS would occur when using 'Copy to Qcad' if only QCADCAM was installed.
  • Undesirable behaviour would occur if the stylesheet.qss file was missing and no previous stylesheet is saved in configuration file. Now, in the event of this scenario, a message will be displayed suggesting how to prevent this error, and that QTD is unable to function, pressing close will terminate the app.
The screenshot is from Linux, in Windows it will look almost identical.
Linux x64.png (155.92 KiB) Viewed 20234 times
Windows setup zip renamed for clarity :oops: :oops:
The Linux x32 zip file has been replaced as there was an error in the install app that prevented the start menu items being created. Download and re-install to display the menu items, but don't forget you may have to log out and in again first !!
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Wed May 18, 2022 8:15 am
Qcad User Theme update, version 7.5
Version 7.5 is a moderate update, it introduces some significant changes, and a few bug fixes. These changes and bug fixes are pretty much the same as introduced in Qcad Theme Designer 3.5 above, so I won't bore you with the details !!
If you are installing the Linux x32 version, you may have to log out and in again to display the menu launchers.
Screenshot from 2022-05-16 15-11-44.png (108.59 KiB) Viewed 19949 times
PLEASE BE AWARE THAT THE COPY/PASTE COLOUR FEATURE PRODUCES AN ERROR.
IT'LL BE FIXED IN THE NEXT VERSION.
Version 7.6 uploaded below that fixes the Copy/Paste error - https://www.qcad.org/rsforum/viewtopic. ... 760#p37760
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Wed May 18, 2022 9:00 am
Qcad Theme Designer update, version 3.6
Version 3.6 is a minor update, it fixes a few anomalies that I found when updating Qcad User Theme 7.5 above.
The install will only overwrite the main app executable, no other files will be affected, including the configuration file.
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Wed Jun 01, 2022 2:41 pm
Qcad Theme Lite update, version v2.0
Version 2.0 is a significant update, it introduces additions and changes as listed below. And even though it's a 'Lite' version, I believe this is now the most useful and easiest app to use out of the three available.
ADDITIONS
  • Brightness and Hue sliders have been added. As these are adjusted you'll see the effect on the stylesheet colours in real time. Their values are saved with the stylesheet.
  • A status bar has been added at the bottom of the app, this will display all hint tips from the drop down menu, tool bar and preview areas.
  • The four tool bar buttons that where on the right side have been deleted and moved to a new drop down menu, along with a few other new menu items. All menu items have a shortcut available. The new menus are as follows...
    • File menu - Open, Save, SaveAs and Quit.
    • Restore Colours menu - Restore All, Restore Background, Restore Check Icon and Restore Brightness & Hue.
      The above menu items restore to their respective saved colour values.
    • Help menu - About and Stylesheet Basic Information.
CHANGES
  • The four tool bar buttons that where on the right side have been deleted and moved to a new drop down menu.
  • As with the latest versions of QTD and QUT, the tool buttons and drop down icon colour list, have been replaced by ones that are more obvious when one has focus, or when the cursor hovers over them, they are also easier to see when using the Tab key to move between the buttons, sliders etc.
  • There have been many visual changes to the preview area. These changes have been made to make the preview area look more like the corresponding areas in Qcad.
This GIF preview was created in Linux, the Windows version will look almost identical.
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Fri Jun 24, 2022 8:54 am
Qcad User Theme update, version 7.6
Version 7.6 fixes the Copy/Paste error.
Please note that this will be the final version of Qcad User Theme. Maintaining three applications that essentially do the same thing has become a bit of a chore. I will continue updating Qcad Theme Lite and Qcad Theme Designer.
Qcad User Theme v7.6 Setup Windows.zip
(2.63 MiB) Downloaded 424 times
QcadUserTheme 7.6 Install Linux x64.zip
(3.57 MiB) Downloaded 389 times
QcadUserTheme 7.6 Install Linux x32.zip
(3.38 MiB) Downloaded 388 times
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Mon Jul 18, 2022 10:20 am
Qcad Theme Designer update, version 4.0
Version 4.0 is a very significant update, it introduces some additions and major changes, all as listed below.
ADDITIONS
  • A status bar has been added at the bottom of the app, this displays all hint tips from the drop down menu, and any controls. It also displays the Undo/Redo count to the right hand side.
  • The Brightness and Hue values can be adjusted by using the ,< and .> keys when either control has focus.
  • An indexed PDF help file is now available by pressing F1.
CHANGES
  • The Undo/Redo function has been totally rewritten, and the old limit of 210 Undo events has been increased 'slightly', the number of Undo/Redo events is now only limited by your system !!.
  • The AutoFill and Preview buttons have been removed. Now, when the Brightness and Hue values are adjusted, the whole preview area, and all the colour buttons are updated in real time. As a safeguard, if an individual colour button is adjusted the Lock checkbox becomes active and the Brightness and Hue controls become inactive.
  • The Gradient and Solid Fill radio button states are now saved with the stylesheet. Their saved states are also displayed in the Stylesheet Information dialogue.
  • Changing the base theme colour used to create in excess of fifty Undo events, now only one Undo event is created.
  • The keyboard shortcuts for Undo and Redo have been changed to Ctrl+Z and Ctrl+Y respectively. Likewise, UndoAll is now Ctrl+Alt+Z and RedoAll is now Ctrl+Alt+Y. These are pretty much the standard shortcuts that most software vendors use.
The GIF preview was created in Linux, the Windows version will look almost identical.
qtd 4.gif (1.23 MiB) Viewed 18589 times
Pete Vickerstaff
petevick
Re: Qcad Theme Apps
Post by petevick » Sat Oct 15, 2022 4:51 pm
Qcad Theme Lite update, version v2.1
Version 2.1 is a critical bug fix.
FIXED BUGS
  • Scenario - a stylesheet is opened with Qcad Theme Lite that was last saved with the latest version of Qcad Theme Designer, if this stylesheet is then saved with Qcad Theme Lite, the stylesheet would become corrupted and Qcad would be unable to load it, the default theme would be loaded in its place.
    Pete Vickerstaff
    petevick
    Re: Qcad Theme Apps
    Post by petevick » Thu Oct 20, 2022 7:39 pm
    Qcad Theme Lite update, version v2.2
    Sorry folks, Version 2.2 is a bug fix of a bug fix !!.
    BUG FIXES
    • Changes made to v2.1 bug fix introduced a bug that prevented the background colour being displayed in Qcad.
      Pete Vickerstaff
      petevick
      Re: Qcad Theme Apps
      Post by petevick » Tue Nov 01, 2022 11:57 am
      Qcad Theme Lite update, version v2.3
      Version 2.3 introduces one change and a minor graphical bug fix.
      CHANGES
      • Grey check and radio button icon colour has been added.
      BUG FIXES
      • Open and Save menu icons corrected.
      Sorry folks I uploaded the wrong files :oops: :oops:
      Pete Vickerstaff
      petevick
      Re: Qcad Theme Apps
      Post by petevick » Tue Nov 01, 2022 12:16 pm
      Qcad Theme Designer update, version 4.5
      Version 4.5 is a very significant update, it introduces additions and changes, and a few bug fixes, all as listed below.
      ADDITIONS
      • Font Control
        This gives you the ability to change the font height and turn on or off bold and italic styles to almost all the widgets in Qcad, either globally or selectively. Additional Font tabs have been added to accommodate this addition.
        Note that some font heights are controlled by Qcad in Edit > Application Preferences. It is not possible to change these via a stylesheet.
        When you open a pre version 4.5 stylesheet, the Fonts tab is visible to the right (depending on your screen resolution, you may have to use the tab bar scroll buttons to display it) this is the Global Font section. Any changes to height, bold or italic will affect the fonts in Qcad globally.
        Checking the 'Click to turn on Font Overrides' check box will display eight areas of Qcad that will override the Global Font settings.
        The 'Sync to Global' button will change all override settings to the current Global settings.
        The 'Defaults' button will change all override settings to their default values, Height is Default and Bold/Italic are unchecked. Note that it's not possible to change the font height for the Menu Bar and Menu Items area for the reason noted above.
        An additional tab, 'Fonts 1' becomes visible when Font Overrides are turned on, this has a further eight areas in Qcad that can be changed overriding the Global Fonts settings.
        Any Qcad widgets that are not covered by these overrides will inherit the Global Font settings.
        Any changes made to any Bold or Italic check boxes will be displayed in the matching preview area, as shown below. Not all Font Override areas have a matching preview area.
        If you Save the stylesheet after turning off Font Overrides, you will not loose any changes you made to overrides until you Quit.
        A stylesheet saved with overrides turned on can be opened and saved in Qcad Theme Lite without affecting the saved font override settings. The font overrides will still be displayed in Qcad after being saved with QTL.
      CHANGES
      • Global Font Overrides status has been added to the Stylesheet Information dialogue.
      • Font display in the Brightness and Hue sliders has been improved.
      • Four colour buttons and their associated text have been been re-aligned in the Base Colours area of the Base, Menu, Combo tab.
      BUG FIXES
      • The Combo box font colour was not being written correctly
      • If a dark theme was using a white base text colour, the preview text would not be updated when the stylesheet was opened from the Open dialogue.
      Pete Vickerstaff
      petevick
      Re: Qcad Theme Apps
      Post by petevick » Thu Dec 22, 2022 1:08 pm
      Qcad Theme Designer update, version 4.6
      Version 4.6 is a significant update, it introduces many additions and changes, and a few bug fixes, all as listed below.
      ADDITIONS
      • A Font 2 tab has been added which contains Font Colour Overrides. This allows you to change the font colour for most of Qcads widgets. These are not affected by the Luminance and Hue slider controls.
        colour overrides.png (27.11 KiB) Viewed 13880 times
      • A popup Preview has been added for the components in Font Overrides that before had no preview.
      • Two colour buttons have been added to the Misc tab. They are in a group box entitled 'Command Background' and control the background colour for the command history and command line widgets. The default colour is the main theme colour. These new buttons use the new popup preview as noted above.
      • An Open Recent menu item has been added in the Stylesheet menu (was File menu). This lists the last five stylesheets opened in a submenu, there is also an option to clear the list.
      • Three Check and Radio icon colours have been added, Grape, Olive and Wheat.
      • You can now open a stylesheet.css file with QTD from the OS file explorer by right clicking on the stylesheet.css file and selecting 'Open With' from the popup menu. You will have to use the 'Open Application' in Linux or 'Choose another application' in Windows the first time you use this method.
      • an Undo and a Redo button have been added to the right of the Luminance/Hue sliders. A single click will Undo/Redo the last change, a double click will Undo/Redo all changes
      CHANGES
      • The main Theme colour is now in it's own group box, and it no longer generates an undo event when it's colour is changed. Instead it generates a flag that lets QTD know that a change has occurred, and a dialogue to this effect will be displayed if you try to exit without saving the stylesheet.
      • The Base Colours group box has been renamed Common (see above).
      • The File menu has been renamed Stylesheet.
      • The Brightness slider control has been renamed Luminance.
      • The Check and Radio Icons drop down list is now alphabetically sorted.
      • Colour and graphical improvements have been made to the check and radio icons.
      • The Luminance and Hue slider controls now change whatever the individual colour buttons are currently set at. Each change made equates to the Undo count increasing by one, irrespective of the number of colour buttons that were affected by the changed slider value.
      • Double clicking the Luminance and Hue slider controls to set to the saved value has been removed as it is now obsolete.
      • Improvements have been made to the loading speed of the folder browser.
      • Improvements have been made to the border colour when adjusting the background to a darker colour.
      • Graphical changes and improvements.
      BUG FIXES
      • An error occurred when in the QTD folder browser if duplicate folders were found, this happens when OneDrive is used in Windows, but could also occur even without OneDrive installed. It could also happen in Linux.
      • An error could occur when selecting the menu item View > Load Configuration File.
      • In certain situations, selecting the View > Load Configuration File menu item or pressing F6 would not load the correct stylesheet.
      • Various Preview elements were not displaying the correct colour in certain situations.
      Pete Vickerstaff
      petevick
      Re: Qcad Theme Apps
      Post by petevick » Thu Dec 22, 2022 1:13 pm
      Qcad Theme Lite update, version v2.4
      Version 2.4 introduces changes, additions and bug fixes.
      ADDITIONS
      • Qcad Theme Lite is now aware of Qcad Theme Designer font overrides. When saving, a dialogue will be displayed with the options to either remove, keep the overrides or cancel. The Stylesheet Basic Information dialogue displays if font overrides exist. A message to the same effect is also displayed to the right of the status bar.
      CHANGES
      • Display improvements have been made when adjusting the Luminance and Hue sliders.
      BUG FIXES
      • If a stylesheet had been saved with Qcad Theme Designer with the base text colour set to white, and then opened with Qcad Theme Lite, the preview text would be displayed as black.
      • Various Preview elements were not displaying the correct colour in certain situations..
      Pete Vickerstaff
      Re: Qcad Theme Apps
      Post by Husky » Tue Jan 03, 2023 11:03 pm
      Hi petevick,
      may I ask you how to get in Windows the Help (F1) for your Designer app? Menu nor F1 triggers no help ... :oops: :oops: :oops:
