[Solved] CoordinateDisplay.js error
333onlyhalfevil
- Full Member
Hello everyone.
I generally run qcad with the debugger enabled (for debugging my own scripts) and I seem to randomly get an error popping up from CoordinateDisplay when using the program normally. It seems to happen when I'm just clicking on stuff and it doesn't happen too often. I took a screenshot of the debugger window that popped up as a result (see attached image). Seems like a weird error. It is saying that CoordinateDisplay.singleShot is not an object (undefined) even though it apparently wasn't undefined on the previous line? Any ideas?
- CoordinateDisplayError.jpg (322.12 KiB) Viewed 75009 times
Last edited by 333onlyhalfevil on Fri Dec 06, 2024 11:10 pm, edited 1 time in total.
Re: CoordinateDisplay.js error
Unfortunately, this is happens because events can occur in the wrong moment while debugging since the debugger forces event processing while running a script. For the same reason, the Qt script debugger can also cause random crashes and should only be enabled when really needed. Note that with Qt 6, the debugger has been removed completely.333onlyhalfevil wrote: ↑Wed Dec 04, 2024 3:14 pmI generally run qcad with the debugger enabled (for debugging my own scripts)
That is very bad news.
Does that mean that users that develop scripts must stick to Qt5?
And how can scripts be debugged under Qt6?
@333onlyhalfevil
I simply ignore them, hit run.
For a steady state you need to run QCAD without debugger.
I then swap frequently between with/without debugger with two QCAD icons on my desktop.
When it hangs there is an issue and then I close QCAD and swap to the debugger mode.
For the time being ....
333onlyhalfevil
- Full Member
Ok. I'll just ignore it then. Thank you both for the replies.
Yep, probably a cursor or click event that is misfired.
Always run your flawless scripts without the debugger mode in a stable environment ... Too.
333onlyhalfevil
- Full Member
Re: [Solved] CoordinateDisplay.js error
i got sick of this one popping up randomly and ended up fixing it. You can fix it by editing the following file https://github.com/qcad/qcad/blob/f06ae ... lay.js#L25 as follows:
The problem is that an undefined gets passed through the script sometimes and causes the debugger to pop up. Line 81 in CoordinateDisplay.js checks if CoordinateDisplay.singleShot is null. Add in another check to make sure CoordinateDisplay.singleShot is not undefined like so: && CoordinateDisplay.singleShot != undefined. You also need to change line 107 to an else if and add in the same two checks for null and undefined. It hasn't popped up since making these edits.
Thanks for your trouble but could you format your solution in code panels.
CoordinateDisplay.js is typically only included as compiled in a standard installation.
Meaning that we have to supersede it with including a custom copy ourselves and the required folder structure + whatever required.
Odd is that isNull(obj) is said to check if the given object is undefined or null, see the library.js script.
The extra test on 'undefined' on line 81 should be obsolete.
It would then fail in line 82 checking the active state of not a QTimer.
I can't let it misfire on purpose with flawless scripts at the moment and can thus not verify if that is the case.
Your own screen capture above displays the error at line 106 (That is from before Commit 5a73fc9 .. Oct 20, 2022)
Mentioned yourself, set to a QTimer on line 103 but failed 3 lines lower.
You can not catch this off by an extra test on 'undefined' in line 81 or 107 (current state).
Because it would fail somewhere between 107 and 111 (current state).
Events are simply not executed at due time or in the correct order in debugger mode.
Things may happen between evaluating and executing 2 lines of JS code.
But if it fixed all of your issues with singleShot ... Then why not.
333onlyhalfevil
- Full Member
Sure, here's the updated function:
CoordinateDisplay.update = function(documentInterface) {
if (!CoordinateDisplay.widget.enabled) {
return;
if (isNull(documentInterface)) {
// clear texts (no document open):
CoordinateDisplay.lAbs.setText("");
CoordinateDisplay.lAbsPol.setText("");
CoordinateDisplay.lRel.setText("");
CoordinateDisplay.lRelPol.setText("");
return;
if (!isNull(CoordinateDisplay.singleShot) && CoordinateDisplay.singleShot != undefined) {
if (CoordinateDisplay.singleShot.active) {
// never mind previous update:
CoordinateDisplay.singleShot.stop();
if (!isNull(CoordinateDisplay.singleShot)) {
// catch exception when ran with script debugger:
try {
CoordinateDisplay.singleShot.destroy();
CoordinateDisplay.singleShot = undefined;
catch(e) {}
// force immediate update every X mouse moves
CoordinateDisplay.counter++;
if (CoordinateDisplay.counter>=CoordinateDisplay.forcedUpdateInterval) {
//CoordinateDisplay.singleShot.start(0);
CoordinateDisplay.timedUpdate();
CoordinateDisplay.counter = 0;
else if (!isNull(CoordinateDisplay.singleShot) && CoordinateDisplay.singleShot != undefined) {
CoordinateDisplay.singleShot = new QTimer();
CoordinateDisplay.singleShot.singleShot = true;
CoordinateDisplay.singleShot.timeout.connect(CoordinateDisplay.timedUpdate);
CoordinateDisplay.singleShot.start(20);
};Interesting. It looks like the comment says that it checks for undefined but the code itself does not. It appears to only check for if the object is deleted, if its null, and if it has a typeof equal to "function". Maybe a simpler solution would be to add the undefined check within the isNull() function. A quick internet search for isDeleted says an undefined is only used in the case of arrays. Maybe that is the confusion.
My memory is a little fuzzy on this since I posted it awhile ago but I seem to remember the error line not being the same line every time the debugger popped up. It always seemed to fail on either line 84 or lines 108-111. It's possible that it is still a problem within flawless scripts because if you continue running after the debugger popup, it will just keep going until it gets back to the beginning where CoordinateDisplay.singleShot gets assigned a value.
This is a good point. Maybe its not completely fixed in that case and it'll end up popping up again eventually. It certainly helped though.CVH wrote: ↑Thu May 15, 2025 11:45 amYour own screen capture above displays the error at line 106 (That is from before Commit 5a73fc9 .. Oct 20, 2022)
It seems your are mixing things ...
CoordinateDisplay.singleShot.destroy(); is deprecated on Mar 22, 2023 (Commit 55d1538)
In a recent installation it should read:
destr(CoordinateDisplay.singleShot);
Basically does the same if a destroy function exists, otherwise it does nothing.
But still, if you are mixing things what have you mixed elsewhere?
333onlyhalfevil
- Full Member
I don't upgrade qcad to the new version every time a new one comes out. It looks like it was rolled back to the CoordinateDisplay.singleShot.destroy() way shortly after your linked commit (v3.26.2.5) and it wasn't updated back to the destr(CoordinateDisplay.singleShot) way until 3.28.
Good thing that I made adding an RWipeoutEntity relative to having the proper resources then (Block Labels).
Perhaps I keep it optionally ... Time will tell.
So, what release are you running?
This is also important to know when formulating an answer for a particular solution.
I stopped updating after v3.27.6.0 but have trial installations aside including the most recent.
v3.27.7 introduced an extreme lag for certain properties of Hatches / solid fills.
v3.27.8 introduced 'Show' buttons for these properties I disliked very much.
Finally fixed in v3.32.0 but in these recent releases my mouse wheel may act strange after visiting the App.Prefs. or a Print Preview.
333onlyhalfevil
- Full Member
I'm on 3.27.6.0 too
