About General Purpose Javascript (ECMA) Syntax? [SOLVED]
Joseph1916
Post by Joseph1916 » Wed Aug 16, 2023 3:16 pm
To all;
OS = Ubuntu Linux 22.04
QCAD = 3.28.1
I have begun coding for a coordinate Geometry program (COGO), and the first thing I noted was ECMA implementation of JavaScript is it dose not recognize General Purpose JavaScript Keywords, such as an assignment command such as "let", as in let x = 1.5....
The objective is to create a large 2d array of point#, x, y, z, descriptions.....
Can that observation be commented on ??
Joseph1916
Re: About General Purpose Javascript (ECMA) Syntax?
Post by andrew » Wed Aug 16, 2023 5:02 pm
You can use var instead of the scoped let which is not supported by Qt Script (Qt 5).
QJSEngine (Qt 6) has some support for let as far as I know.
Post by CVH » Wed Aug 16, 2023 6:19 pm
Joseph1916, You asked that already and it was answered.
Joseph1916 wrote:
Tue Aug 08, 2023 8:06 pm
The reserved term "var" appears in in some of my snippets
CVH wrote:
Wed Aug 09, 2023 1:26 am
Correct, var is the most common way to declare variables.
One should always declare variables.
One can use var the same way:
var myValue = 1.5;
A good idea is to give your variables a meaningful name. :wink:
Isn't x-y-z a coordinate in 3D?
As input or as output to QCAD?
There is already a script of Andrew for inputting such lists.
Joseph1916
Re: About General Purpose Javascript (ECMA) Syntax? [SOLVED]
Post by Joseph1916 » Thu Aug 17, 2023 9:07 pm
Thanks to Andrew and CVH...... var is working fine... I have closed this Topic, and will restart where I left off tomorrow. Thanks...
Joseph1916
