[SOLVED] Font display in vertical tabs.
petevick
Post by petevick » Thu Dec 21, 2023 11:48 am
Possibly one for Andrew.
I've only just noticed that if I set the tab font to italic in a stylesheet, the font displays correctly in horizontal tabs but is ignored in vertical tabs. Setting the font to bold displays correctly in both horizontal and vertical tabs.
Might this be a limitation with vertically aligned text ??
Pete Vickerstaff
petevick
Re: Font display in vertical tabs.
Post by petevick » Sat Dec 30, 2023 11:11 am
On closer inspection, it's not that vertical tabs do not display italics, it's that they don't display italics correctly, the text is slightly distorted as shown in this enlarged screenshot.......
Pete Vickerstaff
petevick
Post by petevick » Fri Jan 12, 2024 9:23 pm
this is a Qt bug that cannot be fixed in QCAD
https://ribbonsoft.com/bugtracker/index ... omment3233
Pete Vickerstaff
