Script needed
Discussion forum for contributors and developers who are using the QCAD ECMAScript development platform or the C++ plugin interface or who are otherwise looking to contribute to QCAD (translations, documentation, etc).
dave5
Script needed
Post by dave5 » Tue May 08, 2012 2:33 am
I need a script that will open a DXF file, convert all the solid lines to the color blue and save the resulting files as a DXF. This script will be executed via the commandline.
Based on my reading of the docs this looks fairly straightforward, but I don't have the time put the script together myself. I would be willing to pay a bounty for this script.
Apologies if this seems a little douche-baggy, but I am under a tight deadline.
Dave
Re: Script needed
Post by andrew » Tue May 08, 2012 9:25 am
I should be able to put this together quickly. I'll post the script here when I'm done.
Re: Script needed
Post by andrew » Tue May 08, 2012 12:54 pm
Attached, you can find a simple script 'ExSetColor.js' and the test drawing I've used.
What the script does:
- find all line entities with linetype set directly to 'continuous' or with linetype 'ByLayer' and the layer linetype 'continuous'
- change the color of those entities to blue
- entities that are not lines are not touched
- entities that have their linetype set to something else than 'continuous' are not touched
Limitations:
- entities that have the linetype set to 'ByBlock' are not touched, even though they might be continuous. This would need some further work as blocks can be hierarchical.
Installation:
- save file ExSetColor.js, e.g. to the QCAD application installation folder.
Usage:
cd [path to qcad]
./qcad -autostart ExSetColor.js [input file] [output file]
Example:
./qcad -autostart ExSetColor.js test.dxf output.dxf
Feel free to donate something if you find this useful.
PayPal: account '[email protected]'
Moneybookers: account '[email protected]'
test.dxf
Example file for testing.
(42.2 KiB) Downloaded 436 times
ExSetColor.js
Script.
(3.02 KiB) Downloaded 470 times
dave5
Re: Script needed
Post by dave5 » Tue May 08, 2012 4:06 pm
Thank you Sir. Works a treat.
This confirms my belief that you guys are onto something really wonderful with QCad 3.
I have made a donation into your PayPal account.
Re: Script needed
Post by andrew » Tue May 08, 2012 4:28 pm
Many thanks for your donation! Let me know if you require any adjustments or to automate other processes.
Return to “QCAD Developers and Contributors”
