Cursor position
Discussion forum for contributors and developers who are using the QCAD ECMAScript development platform or the C++ plugin interface or who are otherwise looking to contribute to QCAD (translations, documentation, etc).
Surendranath
Cursor position
Post by Surendranath » Fri Jan 18, 2013 2:03 am
How do I get the cursor position programmatically?
How do I move the cursor to a specific position on the screen in the program.
I do not have a handle on the event.
Re: Cursor position
Post by andrew » Fri Jan 18, 2013 10:52 am
Surendranath wrote:How do I get the cursor position programmatically?
You should never have to do this. Please use the event handler pickCoordinate instead to receive an event whenever the mouse cursor position changes or the user enters a coordinate.
Perhaps I can be of more help if you let me know why you would like to query the mouse cursor position directly.
Surendranath wrote:How do I move the cursor to a specific position on the screen in the program.
The mouse cursor that is displayed by the operating system cannot be moved other than by moving the mouse.
The position of the cross hairs displayed by QCAD (yellow horizontal / vertical lines) can be set by:
di.setCursorPosition(pos);
Where di is an RDocumentInterface object and pos is an RVector.
Surendranath
Re: Cursor position
Post by Surendranath » Fri Jan 18, 2013 2:26 pm
Say I have drawn a line AB .The cursor is at B. I have to add another line programmatically at the end B of the line. This can be automated if I knew the cursor position without the user again having to click at B. I have to now click at B which fires the coordinateEvent and I am using the event.getModelPosition();
Thnaks
Return to “QCAD Developers and Contributors”
