how to set the size of view
- Active Member
when i create a new null document, the view is small, how can i set it?
Re: how to set the size of view
Please elaborate.
- What is a 'null' document'?
- What do you mean by the 'size' of a document?
Andrew, I think maybe 'Null' means empty ?
- hungerburg
I guess I got it: Its about the initial zoom. Attached screen-shot of what I get; Unit is mm, so display is larger than life. I always have to zoom out first, because my stuff usually is around 1m big. As I always print scaled, font-size is 24mm.
- unit mm
- QCAD-initial-zoom.png (11.32 KiB) Viewed 7164 times
- Active Member
thanks! problem is solved.
