Different verions DXF import
slymn++
Post by slymn++ » Fri Feb 19, 2016 12:17 pm
Hi all
I compiled QCAD3.127.0.
When I open R12 dxf, I get a warning.
"Cannot open file .....dxf imported file.
is the QCAD community supported different versions dxf?
Re: Different verions DXF import
Post by andrew » Fri Feb 19, 2016 12:29 pm
The QCAD Community Edition attempts to load all versions of DXF but always writes DXF R15.
If you cannot load DXF, the DXF plugin was likely not loaded (check under Help > About > Plugins).
