I need help finding the proper script to run the following two functions
1) Select All (Select menu)
2) Delete (Edit menu)
The script will be part of a .js file that I usually run from command line.
Thanks,
Issam
Select All and Delete
Re: Select All and Delete
You could combine the contents of the two scripts SelectAll and Delete into a single command line tool.
Select all:
https://github.com/qcad/qcad/blob/maste ... lectAll.js
Delete:
https://github.com/qcad/qcad/blob/maste ... /Delete.js
Example for a command line tool:
https://github.com/qcad/qcad/blob/maste ... rawings.js
Select all:
Delete:
