development of part library item, script cache?
Matfie
Post by Matfie » Mon Nov 28, 2016 8:44 pm
Hello
As my introduction to QCAD I was writing a scripted part library item, to create a spur gear profile based on given parameters (its working, but the fine tuning is ongoing)
gear.dxf
(36.65 KiB) Downloaded 443 times
one thing that I have found a bit difficult was that when I'm editing this script in an external editor then I save it, I can't seem to run the new version of the script in QCAD unless I exit and restart, which means that making small changes is more involved. Is there a better way to bypass this caching, so that I can force a reload?
Re: development of part library item, script cache?
Post by andrew » Tue Nov 29, 2016 9:37 am
You can try starting QCAD with the -always-load-scripts switch.
