Get the x, y-coordinates of the Point entity in ECMA Script?
laxmanporeddy
Post by laxmanporeddy » Fri Apr 21, 2017 11:31 am
Question : How can I get the x, y-coordinates of the Point entity in ECMA Script?
I have placed DGN file in one location. In scripting file, I have written code to read that file and created RDocument object.
now I would like to get the x, y-coordinates of the Point entity .
Can you please provide some code snippets how to get coordinates in script ?
Re: Get the x, y-coordinates of the Point entity in ECMA Script?
Post by andrew » Fri Apr 21, 2017 2:16 pm
var doc = new RDocument(...);
var entityIds = doc.queryAllEntities();
for (var i = 0; i < entityIds.length; ++i) {
    var entityId = entityIds[i];
    var entity = doc.queryEntity(entityId);
    if (isPointEntity(entity)) {
        qDebug("Point found at coordinate" + entity.getPosition().x + ", " + entity.getPosition().y);
You can search the QCAD sources for some of the functions above to find more / other code examples.
