Deleting/removing entities *updated & SOLVED*
Posted: Thu Aug 31, 2017 3:42 pm
by GnrlSchnavy
Alright, I sort of figured it out. But now, using this code:
	var textID = doc.queryAllEntities(false,false,RS.EntityText);
	for(var i = 0;i<textID.length;i++){
			// print(ID[i]);
			var op = new RMixedOperation();
			entity = doc.queryEntity(textID[i]);
			op.deleteObject(entity);
			di.applyOperation(op);
	var textBasedID = doc.queryAllEntities(false,false,RS.EntityTextBased);
	for(var i = 0;i<textBasedID.length;i++){
			// print(ID[i]);
			entity = doc.queryEntity(textBasedID[i]);
I'm getting these errors:
Warning: RDocumentInterface::applyOperation: transaction failed
Warning: RTransaction::deleteObject: entity not editable (locked or hidden layer)
And none of the TextBased or Text entities are removed.
Just for testing I unlocked all the layers in the DWG, and made all the layers visible, but I'm still getting this error. Any ideas?
I found the problem. It was very specific to the .DWG I was using. The problem is fixed now.
Thanks in advance :)
