Get area of an entity in Script Shell
dfriasb
Post by dfriasb » Sun Sep 24, 2017 5:36 pm
I started scripting and using Script Shell. I managed to get x&y coordinates of lines start&end points and other information, but I cannot get areas. I tried "entity.getArea()", but it looks like this function doesn't exist.
This is the code I'm using:
var doc = EAction.getDocument();
var entityIds = doc.queryAllVisibleEntities();
entityIds = doc.getStorage().orderBackToFront(entityIds);
for (var i = 0; i < entityIds.length; ++i) {
    var entity = doc.queryEntity(entityIds[i]);
    var pline = "" + entity.getId() + " ";
    if (isPolylineEntity(entity)) {
        pline += entity.getArea() + ",";
Any help will be very welcomed!
David
dfriasb@gmail.com | davidfriasarquitecto.es
Re: Get area of an entity in Script Shell
Post by andrew » Sun Sep 24, 2017 10:42 pm
I've added getArea to the RPolylineEntity API for the next release. For now you can use getArea of the underlying RPoltyline shape instead:
entity.castToShape().getArea();
