to get the current directory
Nick1974
Post by Nick1974 » Fri Sep 29, 2017 11:56 am
Hello.
How can I get the current directory from ECMAScript to use it in include, importFile and exportFile commands?
I do not want use full path.
I run qcad as
qcad -allow-multiple-instances -autostart foo.js && qcad foo.dxf
Re: to get the current directory
Post by andrew » Mon Oct 02, 2017 10:27 am
Includes are relative to the script that contains the include.
I.e.:
include("myscript.js");
will look in the same directory as the script that contains that include. Then, it will look in the current working directory (that's the QCAD installation directory that contains the "scripts", "plugins", etc. folders.
For import / export paths, I'd using absolute paths. You can get the current working directory using QDir.currentPath(). See also http://doc.qt.io/qt-5/qdir.html#currentPath
Nick1974
Post by Nick1974 » Wed Oct 11, 2017 1:13 pm
Thanks.
