Free Stand Alone Basic Hatch Pattern Tool *Full Version*
Re: Free Stand Alone Basic Hatch Pattern Tool *Full Version*
Hi All
A small update to allow zero as a gap, if triangles are exploded
it will leave straight lines not multiple lines..previous version did not
allow gaps of anything less than 0.00001 units
More patterns on the way I have a few Ideas...
Version 2.5.1 Downloaded 4 times..
NEW VERSION BELOW ENJOY
Hi All
Well I've been busy today with a new pattern, it's called Weave... it can be used for many things including paving if you set both
height & width the same and tick "Enable Double Weave"
All the Tabs along the top are now sorted Alphabetically just to make it easier to find them Weatherboard was at the front for too long lol..
Also you can use the arrow keys to quickly scroll through the patterns.. see screenshots below of some possibilities with the weave pattern..
9 Adjustable Patterns Now & More to be Added in Future Versions
BHT-V2.6 was Downloaded 7 Times
BHT-V2.6.1 was Downloaded 3 Times
V2.6.1
Added 34 character limit to file name
for compatibility with AutoCad
Even though QCAD does not have these limitations
V2.6.1
- WEAVE-PATTERNS.jpg (347.82 KiB) Viewed 56771 times
- BHT-V2.6.jpg (49.63 KiB) Viewed 56771 times
Hi All
Version BHT-V2.6.2 Now Available to download,
The Program No Longer Exits if There is
Incorrect Input
I've Changed the Message on Last Line
From "The Program Will Now Exit."
To "Please Correct This Issue"
Screenshots of the 9 Adjustable Patterns Below
More to Come...
New Version Further Down
Enjoy
Incorrect Input
More to Come...
Enjoy
- BHT-V2.6.2 - Hatch Patterns.jpg (412.85 KiB) Viewed 56713 times
Hi All
Freeware Basic Hatch Pattern Tool New Pattern Added
Runs in Windows XP to 10 / Tested on Linux Mint [ Wine ]
Runs on 32 & 64bit PC's
Downloads:-
Version 2.0 Downloaded 7 Times
Version 2.1 Downloaded 68 Times
Version 2.2 Downloaded 5 Times
Version 2.3 Downloaded 9 Times
Version 2.4.1 Downloaded 13 Times
Version 2.5 Downloaded 3 Times
Version 2.5.1 Downloaded 4 Times
Version 2.6 Downloaded 7 Times
Version 2.6.1 Downloaded 3 Times
Version 2.6.2 Downloaded 15 Times
Version 2.7 Downloaded 13 Times
New Version Further Down in This Post
Downloads:-
- CROSS PATTERN SAMPLES.jpg (115.74 KiB) Viewed 56630 times
- Cross Pattern Added.jpg (47.61 KiB) Viewed 56630 times
Hi All
New Pattern Added Diamond-01 & Updates to Triangle-01
11 Adjustable Patterns to Date
Downloads:-
Version 2.8 Downloaded 19 Times
New Version Uploaded 2.9 Further Down
Hatch Pattern Tool / Free Hatch Tool / Patterns for QCAD / Hatches / Patterns
Brick Hatch / Diamond Hatch / Grille Hatch / Grill Hatch / Herringbone Hatch / Stud Wall / Triangle / Weave / Roof Tiles
Downloads:-
Hi All
Just to let you know, all these patterns can be altered to produce different results
simply by playing around with the settings for instance below, just swapping 2 settings
Height & Width produces a completely different pattern....
Pattern is also stable at 1000,000 Units not Tiles as previously posted from datum...
Hi All
New Pattern Added "DotCirc" Read the BHT-Usage.txt on how to Simulate a Circle
Please Remember the higher the dot count the more chance there will be of the
pattern causing lag... This pattern was quite a bit of work so I hope you all enjoy
12 Adjustable Patterns to Date
Downloads:-
Version 2.0 to 2.8 Downloaded 166 Times
Version 2.9 Downloaded 19 Times
NEW VERSION LOOK FURTHER DOWN IN POST
Downloads:-
Hi All
Next Version with some more options on BRICK-02 & GRILLE-02, Remember all sizes are adjustable just showing some examples below eg. GRILLE-02 with 2 lines removed resembles the installed ANGLE.PAT file but you can adjust all sides and gap to suit whatever purposes you like. Also remember that you can rotate these patterns so the 2nd pattern can be rotated to create an angle facing the other way..
These are the changes to the existing patterns below:
Here are all 12 Adjustable Hatch Patterns in this Version BHT-V2.9.1
Downloads:-
Freeware BHT-V2.0 to 2.8 Downloaded 166 Times
Freeware BHT-V2.9 Downloaded 19 Times
Freeware BHT-V2.9.1.zip Downloaded 152 times
New Version Uploaded Further Down
Downloads:-
Hi All
This is a totally free hatch pattern maker with 12 adjustable patterns to date
FYI This is a windows 32bit App that runs in Windows 32/64bit & Also Linux using WINE...
In windows the file is saved where the App is executed, in some versions of Linux
the saved file may save in your home folder even if it's executed from the Linux desktop.
I'm using Linux Mint 20 I noticed this behaviour & thought I'd pass this it on..
Hi All
For Linux user running under WINE that would like to add the default icon, here's the icon file.
Copy the Icon to an appropriate place eg. Home/Username/AppIcons
Right click on BHT.exe and select properties and click the icon box top left and replace.
PS Icon is now included in BHT-V3.0.zip + Future Releases
Hi All
1st of all a huge thank you to forum member CVH for supplying all the code for the Herringbone pattern which is based on his XLS file, for more information click on "About?" top right in the program.
Thanks to Husky for initially suggesting the "StudWall" Tab plus UI comments for improving the overall look of BHT.
Thanks to Petevick for lots for testing, bug reporting, UI comments and improvements.
BHT-V3.0 Changes are as follows:-
It is now adapted for both comma and dot users.
It can now minimise to the taskbar.
A User can now enter or select a scale.
Trailing zeros have now all been removed from all patterns eg. 12.30000 now exports as 12.3
Textural information is now added to hatch patterns on export eg: width/height/gap.including a new user comments section bottom right of the application.
Brick-01 & -02 now have an option to offset, an offset of zero will produce a grid, if you want a standard brick pattern click the “[½]” button after defining the Width of Brick.
Herringbone completely recoded by CVH
. Downloads:-
Freeware BHT-V3.0.zip Downloaded 5 times
. Downloads:-
Hi All
One thing I did remove from the herringbone code supplied by CVH was an Information popup window on the pattern image.
It said the following:-
I removed this from his supplied code because most novice users would not understand it's meaning, I did however note in the credits and every exported Herringbone pattern the following text that explains briefly about the 128 ratio limitation:-
Also below, picked up by CVH is an Image and spelling Flaw, These will be fixed up in the next version
Caused by a Dimensioning error by me
I also spelled Horizontal wrong in Diamond-01 & Triangle-01, it's been spelled incorrectly since version 2.8 Cheers
.As rather common, the board ratio L / W can be an integer.
However, with a novel approach, the ratio can also be fractional !
The ratio must then be numerator / denominator with denominators 1 ... 128.
Otherwise, it will be limited to the nearest valid fraction.
And in such case a tiny correction may be applied to the length.
Patterns with high denominators might be less stable in 'the long run'.
; Created with Basic Hatch Tool V3.0 © J.M.Hyslop 2021 ;
; Based on the Herringbone XLS by CVH (C) 2021 all rights reserved. ;
; A method for hatch patterns with uniform or non-uniform boards ;
; and seams with integer and/or fractional board ratios. ;
; The board ratio is limited to fractional denominators up to 128. ;
Hi All
Bug fixes as per previous post, plus a couple of others I found, nothing major
NEW VERSION ADDED BELOW
Hi All
Please read below before downloading:-
1: New option to “Select Save Folder” has been added, the filename is taken from the application only anything typed in at this dialogue will be ignored.
2: The selected folder must be writable and not a system folder that requires admin permissions.
3: New pattern added “Honeycomb”
4: Grille-01 now has the option to remove vertical lines, they will be remarked out on save.
Freeware BHT-V3.0.1.zip Downloaded 143 times
File Removed because I was getting False Positive from Avast.and I can assure you it is not infected .
I've uploaded one not using UPX to compress it..
Enjoy
PS Almost forgot., a big thank you to PeteVick and Husky for there help and suggestions with this release...
Enjoy
Hi All
Avast just triggered a warning on my VM, this is obviously a false positive..
If you are having trouble with the one above "it was downloaded 4 times" , here is the program uncompressed.
I use UPX packer that can sometimes trigger Virus software..
NEW VERSION AVAILABLE ON NEXT PAGE
