Select with polygon
RR88
Select with polygon
Post by RR88 » Tue Aug 25, 2020 3:39 pm
Is 'Select all entities inside a polygon' available in the API?
Arch Linux, QCad 3.22.0 Prof.
Re: Select with polygon
Post by andrew » Thu Aug 27, 2020 9:41 am
No.
However, you could trigger the interactive tool as shown in this example:
include("scripts/Pro/Select/SelectPolygon/SelectPolygon.js");
var a = new SelectPolygon();
a.setDocumentInterface(getDocumentInterface());
a.pointList = [ new RVector(0,0), new RVector(50,0), new RVector(25,50) ];
a.crossSelection = false;
a.selectEntities();
