Linux OS and Windows OS Themes
petevick
Post by petevick » Sat Jan 16, 2021 10:06 am
These themes will display correctly in Linux and Windows only, MacOS has serious issues with them which renders it useless.
All new themes and updates will be posted as attachments in this post only.
Please feel free to adapt the themes to suit your own OS's theme should you so wish. Also let me know if you want a particular theme colour replicated and I'll see what I can do. Also, please let me know if you find any anomalies with the themes, a screenshot would help with debugging.
To use any of these themes, extract the folder from the required zip file and place into QCAD's theme folder. After starting or restarting QCAD, go to Edit>Application Preferences>General>Theme anTotal No of downloads d select the new theme from the drop down box. Press the OK button, close down and restart QCAD, the new theme should be displayed. To install any updated theme, again, extract the folder from the required zip file and place into QCAD's theme folder replacing the existing folder.
Windows 7 is no longer supported by Microsoft, and some themes may display unpredictably. There should be no issues in Windows 10
Updates:
  • 27/11/21 - All themes updated except Default Plus and Dark....
  • 16/03/21 - All themes updated (apart from the Dark theme) updates include....
    • Move all the bottom tabs right so first tab is not floating.
    • Tooltips section removed. Bug in QT forced this.
  • 24/02/21 - All themes updated again!! (apart from the Dark theme) The majority updated to include....
    • Tool Matrix widget header background colour changed.
    • Full set of Checkbox and Radio button icons added.
    • Tab bar and Tabs improvements.
    • General graphical and colour improvements.
    • Added a ToolButton checked state for on/off tool buttons in the Reset, Options and Snap toolbars.
    Screenshots updated to reflect the above modifications.
  • 04/02/21 - Added an additional link to a zip file containing all the themes
    extract all folders in the zip file to the themes folder, overwriting any existing theme folders
  • 01//02/21 - All themes updated !! The majority updated to include....
    • a circular icon when hovering over a radio button,
    • the main menu bar hover background and font colours fixed,
    • a fix for Version and Units text background display in FlexPainter dialog.
  • 27/01/21 - Coffee, Cyan, Dark Grey, Forest, Heather, Light Grey, Pastel and Pink Champagne all updated
    to fix shifting text in menu lists, mainly in WindowsOS and/or Qcad CAM. Update details within each file
New themes:
  • 29/01/21 - Midnight added, based on the system Dark theme.
  • 24/01/21 - Pink Champagne added, suggested by John Hyslop!
  • 18/01/21 - Pastel added
  • 18/01/21 - Forest added, suggested by John Hyslop
  • 17/01/21 - Cyan added, suggested by John Hyslop
  • 13/01/21 - Default Plus added
  • 11/01/21 - Coffee added
  • 10/01/21 - Dark Grey & Light Grey added
  • 08/01/21 - Heather added
all themes.zip
Total No of downloads 174
(370.82 KiB) Downloaded 363 times
Coffee.zip
Total No of downloads 190
(37.01 KiB) Downloaded 381 times
Cyan.zip
Total No of downloads 181
(33.44 KiB) Downloaded 374 times
Dark Grey.zip
Total No of downloads 183
(37.35 KiB) Downloaded 380 times
Dark theme.zip
Total No of downloads 38
(934 Bytes) Downloaded 535 times
Default Plus theme.zip
Total No of downloads 44
(32.89 KiB) Downloaded 518 times
Forest.zip
Total No of downloads 182
(33.54 KiB) Downloaded 361 times
Heather.zip
(50.54 KiB) Downloaded 376 times
Light Grey.zip
Total No of downloads 187
(33.78 KiB) Downloaded 370 times
Midnight.zip
Total No of downloads 167
(33.44 KiB) Downloaded 367 times
Pastel.zip
Total No of downloads 157
(33.42 KiB) Downloaded 354 times
Pink Champagne.zip
Total No of downloads 171
(44.72 KiB) Downloaded 356 times
Pete Vickerstaff
petevick
Re: Linux OS and Windows OS Themes
Post by petevick » Sat Jan 16, 2021 10:16 am
Screenshots
Coffee
viewed 1679 times total
Cyan
viewed 1664 times total
Dark Grey
Dark Grey.png (196.05 KiB) Viewed 15183 times
Default Plus
Default Plus.png (192.54 KiB) Viewed 15183 times
Forest
viewed 1599 times total
Heather
Light Grey
Light Grey.png (205.25 KiB) Viewed 15183 times
Midnight
viewed 1145 times total
Pastel
viewed 1555 times total
Pink Champagne
viewed 1355 times total
Pink Champagne.png (201.44 KiB) Viewed 15183 times
Pete Vickerstaff
petevick
Post by petevick » Sun Jan 24, 2021 8:32 pm
Pink Champagne theme added, suggested by John Hyslop originally as just Pink but then toned it down by adding some Champagne!
Pete Vickerstaff
Post by Husky » Mon Jan 25, 2021 12:00 am
Beautiful - thank you very much!
petevick
Post by petevick » Wed Jan 27, 2021 4:09 pm
** Coffee, Cyan, Dark Grey, Forest, Heather, Light Grey, Pastel and Pink Champagne
all updated to fix shifting text in menu lists, mainly in WindowsOS and/or Qcad CAM **
I'd like to publicly thank John Hyslop for the tremendous help he's been in sorting out these glitches, particularly with WindowsOS and Qcad Cam, neither of which I have. He's supplied me with numerous screen shots in an effort to track problems down, which considering the time difference between us, UK for me and Australia for John, has been no mean feat. I'm not new to pure css code, but these themes throw in QT stuff as well, so it's been a steep learning curve, and I'm still learning!!
Thanks again John :D
Also please post on here if you find any anomalies with the themes, a screenshot would be really help with debugging
Pete Vickerstaff
Post by John Hyslop » Thu Jan 28, 2021 7:59 am
Hi Pete
Your very welcome :)
petevick
Post by petevick » Fri Jan 29, 2021 1:07 pm
** Midnight theme added, based on the system Dark theme **
Pete Vickerstaff
petevick
Post by petevick » Mon Feb 01, 2021 10:10 am
All themes have been updated !! The majority of the updates include....
  • a circular icon when hovering over a radio button, this includes a folder named icons to each theme folder.
This is a stable update release for Linux and Windows 10.
Pete Vickerstaff
Post by CVH » Mon Feb 01, 2021 11:58 am
It seems FlexPainter, and now Tile2Hatch, display perfectly fine in QCAD running on Win 7.
FP & T2H Win7.png (27.09 KiB) Viewed 16171 times
Simply because they are designed using my only hardware and my only software setup.
FlexPainter & Tile2Hatch are built against the 'Default' mode of QCAD3.
On a Windows 7 PC with QCAD PRO installed by the win installer.
Both use common Qt palette settings and Enable/Disable states.
Some usage goes beyond what is commonly done in QCAD.
Then again, there are several hundreds of properties for every kind of QWidgets.
Sorry for your trouble.
PS: the PM explains more but is Off-Topic here.
petevick
Post by petevick » Thu Feb 04, 2021 1:59 pm
Added an additional link to a zip file that contains all of the current themes
Pete Vickerstaff
petevick
Post by petevick » Wed Feb 24, 2021 6:15 pm
Screenshots also updated to reflect the above modifications.
Pete Vickerstaff
petevick
Post by petevick » Tue Mar 16, 2021 7:53 am
viewtopic.php?f=30&t=7994
Pete Vickerstaff
petevick
Post by petevick » Tue Mar 16, 2021 2:57 pm
I'm very pleased and humbled to announce that these themes will be deployed for Linux and Windows systems starting with the next release of Qcad 8) 8) :mrgreen:
Pete Vickerstaff
petevick
Post by petevick » Sun May 23, 2021 8:03 pm
I think there maybe a bug Qcad/CAM. I spotted the problem when a user sent me a screenshot of a theme he'd made. In this first image, you can see the West tabs are facing the wrong way, this is in Linux...
_West-Tabs linux.png (20.05 KiB) Viewed 13224 times
In Windows QCAD/CAM they display correctly.....
I sent the user javascripts that move the tabs East/West/North/South, the following is Linux QCAD/CAM with East tabs, same problem....
_East-Tabs Linux.png (16.93 KiB) Viewed 13224 times
and again, Windows QCAD/CAM East tabs display correctly....
I've tried the same stylesheet in my Linux install of Qcad and it displays correctly.
The North/South tabs in Linux QCAD/CAM display correctly.
All the tabs in the Dark and Default themes in QCAD/CAM display correctly.
So it would appear that the problem is with Linux QCAD/CAM, East and West tabs with external stylesheets.
Also attached is the version details of QCAD/CAM tha the user has installed.
Pete Vickerstaff
petevick
Post by petevick » Sat Nov 27, 2021 12:36 pm
All themes updated except Default Plus and Dark, refer to https://www.qcad.org/rsforum/viewtopic.php?f=30&t=7994
Pete Vickerstaff
