[solved]Problem with script communicating with ui
petevick
Post by petevick » Mon Mar 08, 2021 2:32 pm
I'm expanding my LineBreakSymbol script to include three options in the options toolbar, a checkbox, a spinbox and a pair of radiobuttons. I'm communicating with the ui using the .prototype.slot<....>Changed = function(value) method. I've taken the method from BreakOutManual.js, and based the ui on BreakOutManual.ui but I am unable to get the script to communicate with the ui to update the variables. I also followed the guidance here -> https://qcad.org/en/tutorial-interactive-script-actions and particularly the Adding Widgets to the Options Toolbar section.
I just can't see what I'm doing wrong. script and ui attached. Please help, brain is aching !!
LineBreakSymbol.zip
(2.95 KiB) Downloaded 325 times
Pete Vickerstaff
Re: Problem with script communicating with ui
Post by andrew » Mon Mar 08, 2021 2:40 pm
It's the order of things:
LineBreakSymbol.prototype.slotRemoveSegmentChanged = function(value) {
    this.removeSegment = value;
LineBreakSymbol.prototype.slotBreakHeightChanged = function(value) {
    this.breakHeight = value;
    this.updatePreview(true);
LineBreakSymbol.prototype.slotIncSegChanged = function(value) {
    this.incSeg = value;
LineBreakSymbol.prototype = new EAction();
The last line here overwrites and essentially removes those methods defined above it.
Make sure that
is directly after the constructor function, before attaching any functions to it:
// constructor:
function LineBreakSymbol(guiAction) {...}
// inheritance (defining the prototype):
// methods (attaching functions to prototype):
LineBreakSymbol.prototype.myFunction1 = function(...) {...}
LineBreakSymbol.prototype.myFunction2 = function(...) {...}
petevick
Post by petevick » Mon Mar 08, 2021 2:49 pm
Thanks for the reply Andrew. I've tried moving the LineBreakSymbol.prototype = new EAction(); to after the function LineBreakSymbol(guiAction) {}, followed by the three .prototype.slot<....>Changed = function(value), but then the script hangs in Qcad.
Pete Vickerstaff
Post by andrew » Mon Mar 08, 2021 2:56 pm
If you look at the output in the terminal from which you are starting QCAD, you can see the exception caused by the script:
script engine exception:  "TypeError: Result of expression 'this.startpt' [undefined] is not an object."
Warning:  "<anonymous>(preview = true) at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:143\n<anonymous>(clear = true) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:1714\n<anonymous>(value = 1) at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:53\n<anonymous>(widget = QToolBar, group = 'LineBreakSymbol', signalReceiver = RActionAdapter(0x7fa359c8b600)) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/WidgetFactory.js:830\n<anonymous>(resume = false) at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:409\n<anonymous>() at /Users/andrew/data/RibbonSoft/projects/QCAD3/qcad/scripts/EAction.js:99\n<anonymous>() at scripts/Misc/MiscDraw/LineBreakSymbol/LineBreakSymbol.js:66\n<native>(RActionAdapter(0x7fa359c8b600)) at -1\n<global>() at 1"
You might want to check if this.startpt is defined at the start of getOperation and return undefined if not.
if (!isVector(this.startpt)) {
    return undefined;
petevick
Post by petevick » Mon Mar 08, 2021 3:00 pm
Thanks Andrew, I'll take a look.
Pete Vickerstaff
petevick
Post by petevick » Mon Mar 08, 2021 8:26 pm
Thanks Andrew, again, all working now :mrgreen:
Pete Vickerstaff
