[SOLVED] Close the application
sinase
Post by sinase » Fri Mar 26, 2021 10:30 am
I am trying to close the application by .js code and i don't find that. I try with scripts/Window/CloseAll/CloseAll.js or scripts/File/CloseFile/CloseFile.js but these only terminate the current files.
Is there any other way?
Thanks.
Re: Close the application
Post by andrew » Fri Mar 26, 2021 12:48 pm
Try this:
var appWin = EAction.getMainWindow();
appWin.quit();
sinase
Post by sinase » Fri Mar 26, 2021 1:35 pm
Many thanks.
sinase
Post by sinase » Mon Mar 29, 2021 8:59 am
With the previous code, qcad is running on the background yet ( i can see that in the task manager). I would need to terminate the execution completely, is there other option that i can try?
Thank you.
Regards.
sinase
Post by sinase » Wed Mar 31, 2021 8:13 am
it works as follows:
appWin.quit();
this.terminate();
return;
