[SOLVED] Calculate total area
SM_MaGa
Post by SM_MaGa » Tue Apr 13, 2021 3:42 pm
i am using the Command Line Tool dwg2csv.bat to export and process information about the entities of a .dxf File.
What i am missing is the total area of the Component.
For that i would like to use a self-made script (or any other means to get access to that information) that calculates the total area and exports it
to a file.
Is there any method i can use to achieve that without having to develop everything from scratch or maybe an example that i can use?
Greetings,
SM_MaGa
Re: Calculate total area
Post by andrew » Tue Apr 13, 2021 5:05 pm
What exactly would a "Component" be? Can you please attach a DXF file or screenshot? Thanks for any clarification you can provide.
SM_MaGa
Post by SM_MaGa » Wed Apr 14, 2021 10:55 am
Hi @andrew,
thanks for taking your time.
I attached attached a .dxf as a sample.
By Component i mean the whole thing described by the .dxf File.
Even better if i could exclude Measurement Information (Entities) thats included in the .dxf file, but thats not necessary.
Using the QCAD UI i can use the Polygonal Area tool to calculate the Area but in a script i am not sure about that.
Greetings,
SM_MaGa
Treppe Halle-2.dxf
(3.34 KiB) Downloaded 387 times
Post by andrew » Thu Apr 15, 2021 1:29 pm
As a first step, I would suggest to create a solid fill from the contents. This will only succeed if the file exclusively contains closed contours:
dwghatch -o file_solid_fill.dxf file.dxf
Although currently not included in QCAD Pro, we do have a command line script here that can then output the area of all solid fills or hatches per layer. This would look like this:
dwghatcharea file_solid_fill.dxf
0 : 64717.33669359441
1 : 0
2 : 0
3 : 0
4 : 0
5 : 0
6 : 0
7 : 0
8 : 0
Usage info about dwghatcharea at:
https://qcad.org/en/products/qcad-comma ... ghatcharea
I'm happy to send this to you. Do you have a license for QCAD Professional or are you evaluating the trial version?
SM_MaGa
Post by SM_MaGa » Thu Apr 15, 2021 6:41 pm
That looks very promising!
Yes, please send the command line script to me.
I am using a licensed version of QCAD/CAM on one of my Customers Systems.
SM_MaGa
Post by SM_MaGa » Thu Apr 22, 2021 1:18 pm
The script provided by @andrew provides exactly what i needed. Thus this thread can be closed. Thank you.
petevick
Post by petevick » Thu Apr 22, 2021 2:23 pm
you cam mark the thread closed yourself by adding [SOLVED] to the title of your original post --> [SOLVED] Calculate total area
Pete Vickerstaff
