[SOLVED] Valid colors, how to test?
Post by CVH » Mon Apr 26, 2021 7:14 am
This already bothers me a while:
var colorString = "not-a-color";
var newColor = new RColor(colorString);
var msg = "\'%1\' is a valid color"
if (newColor.isValid) EAction.handleUserMessage(msg.arg(colorString));
var msg = "\'%1\' is NOT a valid color"
if (!newColor.isValid) EAction.handleUserMessage(msg.arg(colorString));
var colorString = "byLayer";
var msg ="\'%1\' is NOT a valid color"
var colorString = "#008000";    // Dark Green
var colorString = "maroon";    // Dark Red
Reported is:
  • 'not-a-color' is a valid color ... (it isn't)
    'byLayer' is a valid color ... (it isn't)
    '#008000' is a valid color
    'maroon' is a valid color
How to test for valid colors as string?
Re: Valid colors, how to test?
Post by andrew » Mon Apr 26, 2021 8:34 am
isValid is a function:
if (newColor.isValid()) ...
A function object evaluates to true if the function is defined. if (newColor.isValid) is always true.
Post by CVH » Mon Apr 26, 2021 5:07 pm
Then I have to repeat the question:
Post by andrew » Mon Apr 26, 2021 8:08 pm
valid = new RColor("something").isValid();
// valid is false
valid = new RColor("red").isValid();
// valid is true
Please note the brackets after isValid.
Post by CVH » Mon Apr 26, 2021 8:49 pm
Noted, thanks.
