Translation proposal
ouilogique
Post by ouilogique » Sun Jul 25, 2021 1:11 pm
QCAD 3.26.4
1. When using the Detect Duplicates command (M, D), the following message translation is incorrect in French:
- Duplicate entities found: 1
- Dupliquer les entités trouvées : 1
It should be :
Nombre d’entités dupliquées : 1
2. By the way the english message
is difficult to translate for a robot, because it could not decide without the context which of these two possibilities to choose from:
- Dupliquer les entités trouvées (= Please, duplicate the entities now!)
- Entités dupliquées trouvées (= How many duplicates are in the drawing?)
So I suggest to change for:
- Duplicate entities count: 1
- Nombre d’entités dupliquées: 1
A collateral benefit of this change is that the text remains the same if there are duplicates or not. Only the count changes.
Re: Translation proposal
Post by CVH » Sun Jul 25, 2021 1:47 pm
Nice!
More something for "QCAD Suggestions and Feedback" :wink:
Post by Husky » Sun Jul 25, 2021 6:33 pm
Thanks ouilogique,
the best place to report translation errors would be here:
https://www.qcad.org/bugtracker/index.p ... ask_id=513
Post by CVH » Mon Jul 26, 2021 4:43 am
http://translate.qcad.org
  • Error 523 Ray ID: 674a9ddffbd3084b • 2021-07-26 03:42:12 UTC
    Origin is unreachable
Seems not to be an issue of one of my browsers ...
Regards
