[Solved] Check for open Contours
SM_MaGa
Post by SM_MaGa » Fri Sep 10, 2021 9:52 am
i am looking for a way to check via script if the outer contours of a .dxf Drawing are all closed.
In my scenario the customer uploads a .dxf File that he wants to be processed but before
doing so we need to check if there are any open outer contours which would make the drawing invalid.
Does anyone have an idea of how i can realise this?
Thanks for your support.
Re: Check for open Contours
Post by CVH » Fri Sep 10, 2021 10:26 am
Here you let us know you have worked out how to find and handle 'contours'.
https://qcad.org/rsforum/viewtopic.php?t=8508
What is left of non-connecting entities are candidates for open contours.
Or by slicing out ids of contour entities from a global id list ... RDocument.queryAllEntities(undone, allBlocks, type=RS.EntityAll)
Or by selecting the found contours and inversing the selection.
This still may need some filtering ... e.g.: Text, solids, hatches .... :wink:
SM_MaGa
Post by SM_MaGa » Thu Oct 07, 2021 5:26 pm
Hi CVH,
thanks four your input.
Thanks to that i could develop a solution for this problem.
I now export all Information needed (Start and Endpoints for all Entities that offer this Information)
and check in the ERP System if each Start/End-Point has a connecting Start/End-Point on the same Contour.
Greetings,
SM_MaGa
