[Solved] Is there an application linear precision?
Post by CVH » Tue Nov 16, 2021 7:25 am
Andrew,
My GUI displays 6 decimal digits: Status Bar, Property Editor, input fields and so on.
Seen screenshots of QCAD GUI in 8 decimals. (e.g. Husky)
A) Is there an application linear precision setting that we can query?
B) How to run QCAD with more or less decimal digits than 6?
Post by CVH » Tue Nov 16, 2021 8:17 am
# Update #
Proposed is 'Drawing preferences' ...
After changing that only the drawing dimensions adapt in my case.
The rest stays in 6 decimal digits fixed.
Re: [Solved] Is there an application linear precision?
Post by CVH » Fri Dec 03, 2021 10:42 am
With the QCAD release there is a setting for the Property Editor decimal digits.
Thanks, Andrew.
rheijman
Post by rheijman » Sun Dec 26, 2021 11:08 pm
Please help with the location of where to set decimal places for the "property editor". Drawing and Application preferences are both set to 4 decimals but property editor still shows 8 decimals.
Post by Husky » Sun Dec 26, 2021 11:44 pm
