[solved] Need to get info global position of a block
sperez
Post by sperez » Sun Feb 20, 2022 8:19 pm
Hi , I'm a begginer developing with QCAD, and I need to solve the next issue:
I'm developing a script in order to get infro about the global position of a block in the draw but if I call the getOrigin() method I always obtain for all of them RVector(0, 0, 0, true).
    var doc = new RDocument(new RMemoryStorage(), new RSpatialIndexNavel());
    var idblock = doc.queryAllBlocks();
    for (var i=0;i<idblock.length;i++) {
        var obj = doc.queryBlock(idblock[i]);
        print (idblock[i]+"-"+obj.getName()+"-"+obj.getOrigin());
If I call the entities inside the block I have obtained the position inside the block , but I need the global position in the draw.
If I select the block inside QCAD ide I have obtained the global position that is what I need to obtain with my code
Santi Perez
[email protected]
Re: Need to get info global position of a block
Post by andrew » Sun Feb 20, 2022 8:39 pm
A block does not have a position in the drawing as a block merely defines the contents of the block. You can think of a block as a separate drawing stored within your drawing. For example, a block "Door" might contain a drawing of a door. An offset may be applied to a block, essentially shifting that drawing by an offset (this is rather unusual in practice). Blocks are not visible in the drawing but they are listed in the block list of QCAD.
What you are likely looking for is the block references. Each block can be inserted into the drawing at various positions, scales and angles. Each such insertion of a block into the drawing is called a block reference. Unlike blocks, block references are drawing entities like lines or arcs and as such are visible in the drawing.
To solve your problem, you'd have to query the list of block references for each block:
doc.queryBlockReferences(blockId)
You can then get the position of each block reference using
blockRef.getPosition()
Note that each block can have zero, one or several block references to it, so there can be no answer or multiple answers to the question "What is the position of my block in the drawing?".
sperez
Post by sperez » Mon Feb 21, 2022 10:22 pm
Ok thanks for your quickly help.
But is It possible yo explode the content of the block with ecmascript ? I have found the way to add, remove, list, ... but I don't know the way to explode.
Post by andrew » Mon Feb 21, 2022 10:25 pm
Yes:
- include("scripts/Modify/Explode/Explode.js")
- select the entities (block references to explode)
- Explode.explodeSelection(documentInterface);
Please post new, unrelated questions to a new topic, thanks.
sperez
Post by sperez » Fri Feb 25, 2022 7:19 pm
Thanks It works perfectly.
