Feature Request for Hatch Command or PolyTrim Tool
Post by John Hyslop » Fri Jan 10, 2020 3:58 am
Hi Andrew
1st of all I’d like to say I’m not requesting to remove current hatches, they will always serve a purpose and I will continue to add to this collection, now using CVH’s Tool.
I currently use Qcad 90% of the time now but find myself going back to AutoCad only to use the Super Hatch Tool (which I think they got the idea from your older version of Qcad).
I think having the ability to create and store a dxf tile is a huge advantage, maybe even include images as well? Others might use that but I and many others would probably only use the dxf tile part.
Pros:
1: Smaller file size (almost half the size, as you can see in my example, Qcad-Logo ) files attached
2: Having the ability to fill non-uniform shapes with laser cutting friendly entities, arcs, circles, splines etc.
3: Fill non-uniform shapes without having to go about this with array or block command and a lot of trimming…
4: Great tool for generating a fast pattern to make garden screens or the like.
5: I see this as a step forward as far as standards go AutoDesk & ProgeCAD offer a similar feature as I mentioned above but their Tool is limited to a block and can only be used in that current drawing.
Cons:
1: I can’t see any.:-)
PS I wasn’t sure where to post this I was looking for a Feature Request Topic but couldn’t find one I did post this in the Chat section but I think that was the wrong place?
Hatch Pattern Options.jpg (34.46 KiB) Viewed 1744 times
Qcad-Logo-Hatch.dxf
(1.62 MiB) Downloaded 99 times
Qcad-Logo-DXF Tile.dxf
(877.32 KiB) Downloaded 96 times
Hatch V DXF Tile.jpg (10.13 KiB) Viewed 1744 times
Re: Feature Request for Hatch Command or PolyTrim Tool
Post by John Hyslop » Fri Jan 10, 2020 7:34 am
Hi Andrew
Or Alternatively a tool like AutoCAD EXTRIM trims everything inside or outside of a polyline of any shape..
that way an array or exploded blocks can be used for pattern..
Usage select polyline then select side to trim ( inside or outside )
see live video attached...
Maybe a script and call it PolyTrim, I bet CVH could write a script for this ;-)
Autodesk AutoCAD 2020 - [Drawing1.dwg] 2020-01-10 17-29-33.zip
(3.53 MiB) Downloaded 95 times
Post by CVH » Fri Jan 10, 2020 9:45 am
Feature request for a Clip2Boundary existed.
See:
https://qcad.org/bugtracker/index.php?d ... sk_id=1983
I linked it to both topics.
viewtopic.php?&t=6865
Remark: Clip2Rectangle exist.
Cheers,
QCADpro 3.24.3.10 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Post by John Hyslop » Fri Jan 10, 2020 9:47 am
Thanks CVH ;-)
Post by John Hyslop » Sat Jan 11, 2020 4:32 am
Hi Andrew
This is a very complex pattern and a nice example to show how a dxf tile would be a good option in the Hatch command :D
The DXF Tile Simulation Exploded is 259KB ( I can move box around without any Lag )
The Hatch Pattern Exploded is 520KB ( Just over twice the size but can move box around without any Lag )
The Hatch Pattern Not Exploded is 221KB ( But if I move the box with Hatch in it the PC Lags )
If anyone wants the dxf files for proof I can supply
Weaving Pattern can be downloaded in the Free Hatch Patterns section :-)
The Pattern is not that big it's only 195 lines and is optimised using CVH's Tile2Hatch
All the other tools I have produce a ridiculous size file some almost 1000 lines...
01-WEAVING Pattern Test.jpg (26.52 KiB) Viewed 1651 times
02-Hatch v DXF Tile.jpg (320.01 KiB) Viewed 1652 times
