Andrew,
As explained in the related post, F5/6 use the center of the bounding box of the current selection.
Then F6 does not counteract F5 ... In al cases.
The solution is to rotate the selection around the centroid of for example a convex hull ... A polygon.
I saw you implementing the centroid of a polygon: commit e98d5f6
This is basically the Shoelace algorithm.
Essentially exactly the same as InfoAreaCentroid.prototype.getPolygonAreaCentroid(polygon)
BUT:
For a large number of tiny segments the naive running sum can suffer from (catastrophic) digit cancellation.
Also: What Every Computer Scientist Should Know About Floating-Point Arithmetic
At some point you start adding (subtracting) small values to already much larger values ...
... While loosing some to more significant digits in the process.
I experienced the same issue when coding the Centroids tools available under Misc .. Information .. 2D Centroids.
Signed area and Centroid position are hardened again digit cancellation as good as it can be.
The solution came from 'A generalized Kahan–Babuška-Summation-Algorithm' proposed by Klein.
Advantages are: Single loop trough and second-order compensation.
Perfectly usable and steady results for long (unsorted) lists of arbitrary values.
Typically the difference of another order of values is a few ULP's off.
The naive running sum may exhibit errors expressed in % of a unit.
The downside is that we have to collect the values in a sometimes vast array.
This robust way of summing large sets of arbitrary values is already at hand and implemented under:
InfoCentroids.prototype.getRunningSumKBK(list)
When things get more complex than 1+1+2-3 I tend to rely on the certainty of result in every code I write.
In preface of what will be included in an upcoming release I did some test, ...
... Comparing the Shoelace algorithm with the naive summing and the centroid returned by the area centroid tools.
With a small set of very distinct vertices the difference is usually less than RS.PointTolerance.
It starts to matter for a larger set and then even more with for example the approximation of a Spline or an Ellipse as a polygon.
The result is no longer steady at any rotation and it is also related to its position in the plane.
To avoid this last issue, 2D Centroids project the shape in question so that it encircles the origin and projects the result back.
About F5/6 and using the centroid as rotation origin
Jump to
- General
- ↳ Announcements
- ↳ Chat
- ↳ Site Feedback
- ↳ Pre-sales Questions
- ↳ Introduce Yourself
- QCAD Professional Version
- ↳ QCAD 'How Do I' Questions
- ↳ QCAD Suggestions and Feedback
- ↳ QCAD Voting Corner
- ↳ QCAD Troubleshooting and Problems
- ↳ QCAD Installation and Upgrades
- ↳ QCAD Programming, Script Programming and Contributing
- ↳ QCAD 'Script Add-On & Plug-in challenge' - Work in Progress
- ↳ Finished 'Ready to go' Scripts/Plug-in's
- ↳ QCAD Tips and Tutorials
- ↳ QCAD/CAM
- ↳ What do you use QCAD/CAM for?
- QCAD Community Edition
- ↳ QCAD Community Edition
- International Forums
- ↳ Français
- ↳ QCAD Professional
- ↳ QCAD/CAM
- ↳ QCAD Community Edition (Version 3)
- ↳ Deutsch
- ↳ QCAD/CAM
- ↳ Italiano
- ↳ QCAD/CAM
- ↳ Español
- ↳ QCAD/CAM
- ↳ Português
- ↳ QCAD/CAM
- ↳ Nederlands
- ↳ QCAD/CAM
- QCAD Book
- ↳ QCAD - An Introduction to Computer-Aided Design
- ↳ QCAD - Una Introducción al Diseño Asistido por Ordenador
- ↳ QCAD - Eine Einführung in computerunterstütztes Zeichnen (CAD)
- QCAD Part Libraries
- ↳ General
- ↳ Creating DXF/DWG items
- ↳ Creating SVG items
- ↳ Meta Data
- dxflib
- ↳ dxflib Suggestions and Feedback
- ↳ dxflib 'How Do I' Questions
- ↳ dxflib Troubleshooting and Problems
