Bounding Box
Moderator
Bounding Box
Post by Clive » Thu Dec 04, 2014 1:09 pm
The bounding box tool is a great feature and to be honest I've only just got around to using it more, here is my feedback so far.
Using this tool from either the shapes toolset or the drop down menu 'misc' tools gives two different results.
From the Shapes toolset
Using the tool from here on a shape with seperate single entities gives the correct expected result by bouding the shape with a circumscribed rectangle hitting the outside points - with options to create polyline, offset distance etc.
Shape consisting of seperate line entities.
Bounding Box pic 1.png (20.85 KiB) Viewed 6444 times
From the 'drop down' menu misc tools
From here the tool gives you a bounding box hitting all of the end points of all of the entities ... unless it is a polyline!
I also think this tool would be better in the modify toolset (or another, but not sure which one at the moment) as currently you only come across it by using the shape tools, but if you create with arcs, splines etc it would be more easier seen from a more common place.
Bounding Box pic 2.png (27.4 KiB) Viewed 6444 times
Re: Bounding Box
Post by Husky » Sun Dec 07, 2014 1:58 am
Clive wrote:The bounding box tool is a great feature and to be honest I've only just got around to using it more, here is my feedback so far.
Indeed a helpful tool ... but where is it now????? It's just gone in 3.5.7 or do I miss something ..... :cry: :cry: :cry:
Moderator
Re: Bounding Box
Post by Clive » Mon Dec 08, 2014 9:32 am
Husky wrote:Indeed a helpful tool ... but where is it now????? It's just gone in 3.5.7 or do I miss something ..... :cry: :cry: :cry:
It is indeed missing from the latest version of QCAD, Andrew has pointed out to me that this tool was developed for a customer and is owned by the customer, the tool was added to QCAD by mistake. The good news is that Andrew has said that he hopes to develop something similar for QCAD as time permits.There is still the Bounding Box tool from - Main Menu > Misc > Darw > Bounding Box, although this tool has limited features.
Who knows Husky maybe we will get something for Christmas.
Re: Bounding Box
Post by Husky » Mon Dec 08, 2014 9:50 am
Ok Clive - thanks for the Info!
Christmas? We will see! :wink:
