Plans for move to QT5?
mink
Post by mink » Tue Feb 03, 2015 3:16 pm
are there any plans to move to QT5? What's up for new releases?
Just asking for the future, as our users might some time want to use QCad on a tablet...
Ulrich
Re: Plans for move to QT5?
Post by andrew » Tue Feb 03, 2015 3:23 pm
QCAD can be compiled against Qt 5 since about Qt version 5.2. However, there was one bug in Qt 5 which held back a Qt 5 based QCAD release for a long time: https://bugreports.qt.io/browse/QTBUG-37926
This bug basically meant that mouse clicks at x,y arrived at a completely different locations in QCAD. This bug should be fixed in Qt 5.4, so there's nothing in the way of a Qt 5 based QCAD release anymore.
As far as tablets go, I can confirm that QCAD sources can be compiled for Android (tested) and likely also iOS (not tested until now).
mink
Post by mink » Tue Feb 03, 2015 3:33 pm
Thanks, that's a real explanation! I love the answer ;-)
Jalal Kettani
Post by Jalal Kettani » Thu May 25, 2017 12:21 pm
andrew wrote:...QCAD sources can be compiled for Android (tested) and likely also iOS (not tested until now).
Is the iOS version available ?
Jalal
Post by andrew » Mon May 29, 2017 8:09 am
No, we currently have no plans to spend any resources on a QCAD version for iOS / Android.
