QCAD 3.17.2 alternative projection types
Post by Husky » Tue Jun 27, 2017 7:35 pm
Hello Andrew,
this new possibility to use my own projection types in 3.17.2 is just beautiful! Thank you for this new feature! :D
Question: If I need to use a grid regarding to my own projection settings then there is currently no way to reflect those angles in the grid, correct?
Re: QCAD 3.17.2 alternative projection types
Post by Husky » Tue Jun 27, 2017 8:17 pm
BTW: After decades of faithful service, my dimetry drawing template can go into it deserved retirement ... :lol: :lol: :lol:
... RIP!
Post by andrew » Tue Jun 27, 2017 10:11 pm
Husky wrote:this new possibility to use my own projection types in 3.17.2 is just beautiful! Thank you for this new feature! :D
Thanks for the feedback. I'm glad you like it.
Husky wrote:Question: If I need to use a grid regarding to my own projection settings then there is currently no way to reflect those angles in the grid, correct?
That's correct, yes.
Moderator
Post by Clive » Thu Jun 29, 2017 12:20 pm
'User defined' projections - brilliant, brilliant, brilliant, brilliant,
Thanks Andrew :D
Post by andrew » Fri Jun 30, 2017 10:23 am
You're welcome. I've also added Cabinet 30° and Dimetric (7°/ 41°) to the available standard projections for the next release 3.17.3.
Post by Husky » Fri Jun 30, 2017 4:24 pm
andrew wrote:You're welcome. I've also added Cabinet 30° and Dimetric (7°/ 41°) to the available standard projections for the next release 3.17.3.
... even better. :D
I guess that is just a typo but Dimetric has 7°/42° ...
Post by andrew » Fri Jun 30, 2017 4:28 pm
Yes, sorry 7°/42° :)
