Global Lineweight preference?
Dacicusan
Post by Dacicusan » Sat Oct 14, 2017 2:11 am
I'm just trying to set the "Lineweight" attribute of all the layers in all the drawings that I made to be 0.00mm and as I can see the Qcad default it is set to 0.25mm and I can't find any option to globally change this setting. It is possible to add an option to the "Application Preferences" to set this? It is quite time consuming to change manually this setting.
Re: Global Lineweight preference?
Post by Husky » Sat Oct 14, 2017 3:20 am
Hello Dacicusan - welcome to the forum,
Dacicusan wrote:I'm just trying to set the "Lineweight" attribute of all the layers in all the drawings that I made to be 0.00mm and as I can see the Qcad default it is set to 0.25mm and I can't find any option to globally change this setting
Dacicusan
Post by Dacicusan » Sat Oct 14, 2017 3:44 am
Thank you. Very useful.
