How to change the Lineweight for the "0" Layer?
Dacicusan
Post by Dacicusan » Sat Oct 14, 2017 11:16 am
I want to change the Lineweight for the layer "0" globally, so that every time I'm creating a new file to have Lineweight as 0.00mm but seems that it is not possible? In the preferences, the Layer/Add Layer/Default Lineweight for new layers seems to don't have any effect for the "0" layer. It will be great if the Lineweight preference from Settings will change also the Lineweight for the "0" layer as I set for all the new created layers.
Re: How to change the Lineweight for the "0" Layer?
Post by andrew » Tue Oct 17, 2017 11:59 am
I can confirm that the configured layer default color and default lineweight will also be used for the initial layer 0 in the next release.
Panchdara
Post by Panchdara » Fri Nov 10, 2017 11:42 pm
I see this, but what exactly is the "default" line weight? I mean in real terms? Sorry to sound dumb, but where is "default" set and what is it's weight?
Windows 10
Post by andrew » Fri Nov 10, 2017 11:47 pm
This value exists for compatibility only. It's one of the possible values for line weight as per DXF/DWG standard. In QCAD, the default line weight is treated the same as 0.00mm, i.e. the smallest possible line weight for the device and cannot currently be changed.
