It would be nice to have "Update View" in the View List sub-menu. As a part is developed, the view will change, expand. So instead of removing the view and adding it again to the view you currently need, a simple update view would kill two birds with one stone. Just delete the named view and add it back as new all in one click. Or, better yet, to keep in the same groove as the rest of QCAD, click the view you need to change/update and give it [U, V]. Just a thought.
Thanks for listening.
Slyde
[solved] Update View on List View
Look! It's a bird. No! It's a plane! NO! It's QCAD hotkeys...faster than a possum falling out of a tree!!
OS: Linux Mint 18.3 Sylvia [64-bit]
QCAD Pro 3.19.2.0 [64-bit]
Re: Update View on List View
Correct! What I do in cases like that is:slyde wrote:As a part is developed, the view will change, expand.
Chose the particular "View",
Adjust the view regarding the development of the drawing,
Click the option "Pick View" and it will overwrite the selected View - done.
I was treating it black and white without exploring any "possibilities". Thanks for the tip, Husky. I withdraw my request
Re: [solved] Update View on List View
This doesn't seem to be working for me. I select a view, change zoom/pan, click "pick view" but when I select the same view again it's back at its previous settings.
QCAD Professional
Version: 3.21.0.0 (3.21.0)
Revision: 7838ad7
Qt Version: 5.5.1
Compiler: MSVC++ 12.0 (2013)
QCAD Professional
Revision: 7838ad7
Qt Version: 5.5.1
