PDF Export
Jam35
PDF Export
Post by Jam35 » Wed Jul 31, 2019 1:37 pm
When exporting a drawing as a PDF, the destination folder is not remembered next time.
Is it possible to change this behaviour? All other save operations afaik will default to last used.
Trying to think of a reason that this would not already be standard behaviour.
JoseVieira
Re: PDF Export
Post by JoseVieira » Fri Dec 27, 2019 11:30 pm
Jam35,
I think that this feature is good, as if the folder where the last PDF was saved would be remembered, this would make a lot of confusion.
Figure that you end a job and export your work to pdf to send to costumer. After that you sart a new job at another folder. Weeks after that, when you finish the new job you quikly export to pdf and... where just is that folder of the last work that I did the month after?
This is my opinion, but I can be wrong.
Re: PDF Export
Post by CVH » Sat Dec 28, 2019 3:42 am
Indeed double situation.
Evaluating pros and cons it might better be not.
Remembering last opened dir and last saved to, that makes sence.
And for now last used will do nice.
